It is currently 28 Mar 2024, 19:51
Clock, cherry
Clock, cherry
Postby Andyp » 18 Sep 2016, 10:32
Hardly worthy of a thread as it is only a polished bit of wood with a hole in the middle. Only took a couple of hours from log to hanging it on the wall. Most defiantly cherry as I cut the tree down myself more than 10 years ago in my FIL's garden.
I'll not show the back as it did not occur to me to make the hole for the movement on the lathe. :oops: Instead I chopped it out on the morticer.
Re: Clock, cherry
Postby DaveL » 18 Sep 2016, 12:14
You did well to dry that without it cracking. Polished with the buffing mops, looks like you have mastered them, nicely done.
Regards,
DaveL
Re: Clock, cherry
Postby Andyp » 18 Sep 2016, 12:48
Dave, thanks. It was cut, sealed both ends and left as a log in FIL garage for about 6 years. When I finally got it here there was cracking at both ends. One end I cut off and have been cutting slices off it for the past 3 or 4 years. It started off at about 5 ft long now reduced down to about 3. Log diameter is between 7 and 8 inches
Yes it was buffed with the mops. Actually I am very impressed with how nice it looks considering it is end grain.
Re: Clock, cherry
Postby Doug » 18 Sep 2016, 13:35
Might be simple Andy but it looks effective :eusa-clap:
Doug
Re: Clock, cherry
Postby Andyp » 18 Sep 2016, 20:10
Thankyou Doug.
Re: Clock, cherry
Postby Phil » 19 Sep 2016, 07:11
Andy, looks very good and different on the end grain.
Are you going to add some nice Walnut 'dots' for the numerals?
Re: Clock, cherry
Postby Pinch » 19 Sep 2016, 09:01
Very nice indeed. 8-)
Pinch
Re: Clock, cherry
Postby Andyp » 19 Sep 2016, 09:24
Phil wrote:Andy, looks very good and different on the end grain.
Phil, I did think of doing that but eldest daughter says she is old enough to tell the time without them. We will see if it improves here timekeeping.
Re: Clock, cherry
Postby Andyp » 19 Sep 2016, 09:25
Pinch wrote:Very nice indeed. 8-)
Thanks Paul.
Re: Clock, cherry
Postby Dalboy » 19 Sep 2016, 19:08
Sometimes simple is good Andy, any more and you would take away the beauty of the grain pattern
Dalboy
