It is currently 27 Apr 2017, 08:17
Chestnut bowl with walnut inserts
Re: Chestnut bowl with walnut inserts
Postby Andyp » 09 Jan 2017, 10:32
Thanks Richard,
Glue is something I am very conscious about with this sort of turning. For keeping the piece together on the lathe and for robustness is normal use.
I have been using PVA - Evostick Resin W, waterproof, up to now. But it has been suggested that PVA can be liable to movement and that Cascamite would be a better bet. I have also been told that Titebond 3 would be a glue better than PVA.
Further thoughts would be welcome.
Postby Mike G » 09 Jan 2017, 10:34
Careful with the colour of Titebond. At least one of them (and I can't remember which) dries a nasty dark brown colour.
Postby Dalboy » 09 Jan 2017, 14:50
Andyp wrote:Thanks Richard,
I have have experience of creep with pva even though it is all lined up and set I found small ridges appear after a while so for any work where I use more than 1 piece of wood I use cascamite.
Dalboy
Postby Andyp » 09 Jan 2017, 18:59
Thanks Derek. I have a couple of small pots on order.
Postby Andyp » 09 Jan 2017, 19:01
Mike G wrote:Careful with the colour of Titebond. At least one of them (and I can't remember which) dries a nasty dark brown colour.
A quick google confirms that it is the Titebond 3 that leaves a dark glue line.
Postby justaskin » 16 Jan 2017, 08:04
Hi Andy
Many thanks for the reply, always very interesting what others prefer. I always now use cascamite as the other liquid varieties discolour lighter colours wood close to the seam, also is not so susceptible to timber movement due to atmospheric conditions.
Richard
Oh and is cheaper :lol:
You think its difficult try herding cats
justaskin
Location: Shenley Church End MK(the legion of the lost)
Postby Woodster » 26 Jan 2017, 17:08
Very nice job Andy. I turned a similar one but I used bubinga (I think) inserts about 22mm thick in a Maple bowl about 7" diameter.
Postby Andyp » 26 Jan 2017, 17:15
Hi Woodster and welcome and thanks for your kind comments
After your third post you will be able to post images. Please do as we love to see what other woodworkers are up to,
Postby Woodster » 26 Jan 2017, 18:03
Mine started out like this. As you can see I started with a round bowl blank. Not ideal for glue up but it worked out ok.
I don't have a decent picture of it finished, I'll have to take one.
Postby Andyp » 26 Jan 2017, 18:35
Woodster wrote:Mine started out like this. As you can see I started with a round bowl blank. Not ideal for glue up but it worked out ok.
Yes please. Suggest you create a new thread for as it is bound to show my one up. :D
Postby Woodster » 26 Jan 2017, 18:52
Done.
viewtopic.php?f=24&t=2410
It's not a very good shot, just a quick picture taken on an iPad.
Previous
