It is currently 28 Mar 2024, 15:20
TrimTheKing wrote:Cool! Would look really good using something like Sycamore and ABW…
Mikesimamwo wrote:Well done Andy, you can be very proud of your work, it looks great. Yes I suppose a more contrasting wood would have made it have more contrast, but yours still looks perfectly ok. I had the same problem with the 2 small disks, I now just use a forstner bit to make the holes and then turn the disks on the lathe with a very small taper and make them slightly taller than the depth of the hole, so it is being wedged into the hole. Thank you for the acknowledgment it is very much appreciated. Keep in touch with your projects, and good luck with your next Yin & Yang.
Mike
mike@simplyamazingwood.com
selectortone wrote:Very nice!
Dalboy wrote:The pieces fit together a treat and I can see why you would need a template to achieve that. Maybe next time as already stated more of a contrast with the timbers.
Well you have done more than me Andy as I have not been in the workshop for just over a month due to being laid up but now spending 10 to 20 minutes in there now hoping to increase that.
Andyp wrote:........I must acknowledge Mike Urquhart from whom I purchased the templates. I tried without success to make make my own.
Mike G wrote:Andyp wrote:........I must acknowledge Mike Urquhart from whom I purchased the templates. I tried without success to make make my own.
Yebbut.....
......at no stage did you ask me to draw it for you. I could have sent you PDF's to print and stick on, at full size, which would have solved the problem without buying a template. Seconds of a job, literally.
Woodster wrote:Nicely done. Very good glue up.
Phil wrote:That looks very nice Andy.
There are a couple pics on the web using the same design for T-light candles, 2 separate pieces.
https://www.google.com/search?q=yin+yan ... 20&bih=953
The accuracy of the 'join' or gap is not that serious.
Andyp wrote:Phil wrote:That looks very nice Andy.
Thanks Phil. I has seen those two piece items but where is the challenge in that.
Andyp wrote:
I would wager it is not possible to fabricate and glue those two halves together without starting with a perfectly matched template.
