It is currently 28 Mar 2024, 16:58
RogerS wrote:Do you have to soak the wood in anything to stop the spalting falling to bits as you turn it ?
Another from me.
Another from me.
Andyp wrote:Thanks Derek,
I do seal all turnings with sanding sealer prior to finishing.
Dalboy wrote:Andyp wrote:Thanks Derek,
I mean use the sealer to stabilise while turning to help harden the piece if the wood is a little soft. I know you would put something on for the finish
Andyp wrote:Dalboy wrote:Andyp wrote:Thanks Derek,
Interesting Derek. How often would you need to apply the sealer while turning? Surely it would harden but scrape off in no time.
Coley wrote:That clocks a cracker !
