It is currently 29 Mar 2024, 02:13
Andyp wrote:Nice haul Derek, well done. You must gave a lot of space to store it all.
Malc2098 wrote:Wow!
How long before you can work with them?
Rod wrote:A nice haul but why are they chopping the trees down?
Doug wrote:Free timber is always a bonus Derek & especially when it’s on your doorstep, nice haul
TrimTheKing wrote:Oooooh lovely.
titch22 wrote:Drooling over your logs. As an artist there is so much potential in them, there logs
Dalboy wrote: and given a coat of emulsion as a temporary measure.
Phil wrote:Very nice haul!Dalboy wrote: and given a coat of emulsion as a temporary measure.
Derek, what sort of emulsion are you using to coat>
Dalboy wrote:Phil wrote:Very nice haul!Dalboy wrote: and given a coat of emulsion as a temporary measure.
Just the normal household stuff it is just a stop gap and I have some part used cans laying around from decorating. I like to give it a heavy coat where possible
Phil wrote:
Water or oil based? and what do you use as a long term sealer?
It is water based.
For the final seal I use thinned PVA I have found it seals nicely have been using it for ages and uses up all the older bottle I have had for a while. Like most drying you will get failures but on the whole I seem to get very few that split.
Starting tomorrow I will be rounding some off as I need to reduce the storage area that a piece takes up before doing this. I also will be stacking them in blank size(Diameter) and wood type. Each will be marked with weight and date.
Rod wrote:I used to seal mine with melted candle wax, it’s a bit messy though but provides a good seal. I bought a cheapo small electric ring and a large bag of wax beads and used an old large saucepan.
