It is currently 29 Mar 2024, 08:55
mabazza ritchie wrote:Evening folks,
Rather excitedly I took delivery of my new lathe today. It took a lot of effort to get the pallet truck across my gravel driveway, although leap-frogging some chipboard made it marginally easier. I will update once I have it all together and set up. It is covered in oil which I intend to clean off. Would I be best to use white spirit to do so?
Thanks
MR
Woodster wrote:Strange, was this bought from a UK supplier? If so shouldn’t it have been fitted with a UK 13 amp plug?
I now just need to practice sharpening freehand on a 6inch bench grider and I'll be ready to go! I still need to source the right grinding wheels for my budget supermarket grinder.
Thanks.
mabazza ritchie wrote:...aside from the obvious is there any difference in finish etc between a wet or dry system?
Thanks.
