Rod wrote:I was quite surprised with all that spraying, that he didn’t cover the lathe bed etc??
I had similar thoughts.
When I oiled anything on the lathe, everything around the lathe got covered.
It is currently 29 Mar 2024, 07:23
Woodster wrote:Having got stain I couldn’t remove on a previous Lathe, the first thing I did with my current lathe was to give it a coat of Renaissance wax. This includes the lathe bed, and contrary to what you may think doesn’t stop the Banjo or Tailstock from locking up. It does however make them slide smoothly when required.
mabazza ritchie wrote:
I think I will follow your lead with the Renaissance wax. Would machine wax from Ax do the same job?
I’m sure the Axminster machine wax will be fine. It’s what I’d use if I didn’t already have the Renaissance wax. Just wipe on then buff the surface a little.
Rod wrote:Any soft paste wax will work as long as it’s silicon free
Rod wrote:You don’t want to contaminate wood with silicone polishes as it prevents other finishes penetrating and can leave a fish eye appearance.
