It is currently 29 Mar 2024, 09:14
Dalboy wrote:For the bulge I would just wrap a piece of sandpaper around a block of wood and sand it down. The other split where you only used one plug I feel should have a couple more as it looks wrong with just the one. Having said all of that it does look good and as if it was part of the design rather than a repair
Andyp wrote:Dalboy wrote:For the bulge I would just wrap a piece of sandpaper around a block of wood and sand it down. The other split where you only used one plug I feel should have a couple more as it looks wrong with just the one. Having said all of that it does look good and as if it was part of the design rather than a repair
Thanks Bob,
Darn you for suggesting I add an extra couple of holes. I thought I had finished with drilling and plugging. You are right though.
Woke up in the middle of the night with a solution for the base. I had not mentioned this before but it is not flat and it is far to big to get any sort of reverse chucking solution. There is less than 1/2" gap between the bowl and lathe bed.
Andyp wrote:Oops Sorry, Derek.
Dalboy wrote:Good rescue Andy at least all the effort was not wasted before the cracksAndyp wrote:Oops Sorry, Derek.
It happens Andy
Woodbloke wrote:Nice job...and it's been signed - Rob
Andyp wrote:Woodbloke wrote:Nice job...and it's been signed - Rob
I remembered but I think it looks awful. I like the idea of merging by initials together but doing it freehand is not good.
Woodbloke wrote:Andyp wrote:Woodbloke wrote:Nice job...and it's been signed - Rob
I reckon you need a bit more of an artyfarty flourish to your initials, then it would look fine. It also currently reads AP Beech on the bowl...relative? - Rob
selectortone wrote:That's a good rescue there Andy - well done sir!
