It is currently 28 Mar 2024, 23:38
Ornamental cherry
Ornamental cherry
Postby Dalboy » 07 Jul 2019, 21:43
Ornamental cherry which once stood in my garden. Turned from the trunk which is only 6" diameter as it was only a young tree. Finished with Acrylic sander sealer and an Acrylic gloss lacquer. Measures 6 1/2" X 4 1/2" X 3 1/2". Managed to lose the bark amongst the shavings so no chance of sticking it back on.
(105.5 KiB)
(93.59 KiB)
(94.71 KiB)
Dalboy
Re: Ornamental cherry
Postby Malc2098 » 07 Jul 2019, 22:53
Wow!
Vey 'now'. Or was it 'then'?!
Postby Woodbloke » 08 Jul 2019, 13:18
Currently reading the story of 'Cherry' Ingram, the Englishman who saved Japan's cherry blossoms. Fascinating stuff - Rob
Postby Andyp » 09 Jul 2019, 07:22
As with so many of your turnings Derek I am left wondering, How? And Wow!
Postby Dalboy » 09 Jul 2019, 13:33
Thank you all.
Andyp wrote:As with so many of your turnings Derek I am left wondering, How? And Wow!
Turned from a small trunk 5" to 6" diameter across the bed and not spindle turned you can see the centre of the tree in the sides
Dalboy
Postby Andyp » 09 Jul 2019, 15:32
Did you have to reverse chuck it? If so how?
Postby Dalboy » 09 Jul 2019, 16:55
Andyp wrote:Did you have to reverse chuck it? If so how?
If you mean to remove the foot then yes I did.
When I cut the tenon to turn the inside I made a small dimple in the centre of the tenon this helped later
I fitted a piece of wood in the chuck and shaped it to match the inside of the bowl. I use a piece of router mat between the wood and the bowl to protect the piece.
I put a revolving centre in the tailstock and brought this up and placed it in the dimple I mentioned, Then turned as much of the tenon away and sanded removed from lathe to finish the small amount left from holding it and sanded to blend in with the rest.
Hope that makes sense
Dalboy
Postby Andyp » 10 Jul 2019, 07:25
I understand but am amazed that without a complete rim it stays put.
Postby Dalboy » 10 Jul 2019, 08:53
Andyp wrote:I understand but am amazed that without a complete rim it stays put.
The rim does not touch anything the bowl is supported by the jam chuck (the wood piece) inside the bowl and the tailstock is supporting the tenon end. Never had any problems doing it this way.
Dalboy
Postby Andyp » 10 Jul 2019, 13:11
I guess I just lack the confidence to try that method.
