It is currently 25 Feb 2018, 00:28
Compound Cut Christmas Tree Decoration
Postby Gill » 15 Oct 2015, 16:19
I fired up the ole Hegner and relentlessly abused a bit of B&Qs finest banana pine.
Eventually it yielded up a Christmas tree decoration
It should look okay once it's tidied up a bit. Now, where did the removal men hide my needle files...
Gill
Re: Compound Cut Christmas Tree Decoration
Postby Andyp » 15 Oct 2015, 16:41
What's happened to the images Gill?
Postby 9fingers » 15 Oct 2015, 16:56
They seem to be stored on farcebook - don't know if the forum softwsre can cope with that Andy.
Postby Andyp » 15 Oct 2015, 17:00
Ah Yes, I forgot as a mod I could edit and see the links.
Facebook is telling me this if I follow the link.
Sorry, this content isn't available right now
The link you followed may have expired, or the page may only be visible to an audience you're not in.
Go back to the previous page · Go to News Feed · Visit our Help Center
Postby 9fingers » 15 Oct 2015, 17:09
I can never get farcebook to work for me. None of the clickable links work for some strange reason.
But it seems in order to do anything or see anything you have to login. If that is true then the forum software would not be able to look anything up anyway.
Postby Andyp » 15 Oct 2015, 17:19
OK I have run a test Bob, Checkout Private Parts and let me know.
I did not sign into facebook but did view the BBC R2 page and copied the image location of the selected image and then pasted it between the Img tags. Seems to work.
Gill, let me know what you did with the images above and I'll try to sort it out.
Postby Gill » 16 Oct 2015, 15:55
Sorry the photos didn't make it. I'm a bit of a novice with the tablet I'm using. Hopefully, these turn out better.
Gill
Postby Rod » 16 Oct 2015, 16:04
Not for me?
Rid
Postby TrimTheKing » 16 Oct 2015, 17:03
Nope, something definitely worn with those picture links. I copied one into the address bar and it doesn't load…
Postby 9fingers » 16 Oct 2015, 17:32
TrimTheKing wrote:Nope, something definitely worn with those picture links. I copied one into the address bar and it doesn't load…
Both loaded for me from the address bar but nought from the image tags
Postby TrimTheKing » 16 Oct 2015, 17:54
Hmmmm, loading in address bar for me now but defo just hung earlier.
Postby Andyp » 16 Oct 2015, 18:47
here you go. I hope
No lets see if I can explain how I did it.
I copied the URL into Firefox Address bar. This then opens up Google Photos with a small version of the image. I then clicked on the image which opened up a larger version also in Google Photos where I could Right Click and select View Image Info. I then copied the image location and pasted between the Img tags.
Hope this helps Gill.
Postby chataigner » 18 Oct 2015, 09:52
That looks lovely Gill. Look forward to seeing it cleaned up now the picture posting issues have been resolved.
Cheers !
http://www.rue-darnet.fr
chataigner
Postby Wizard9999 » 18 Oct 2015, 13:41
How on earth do you do that??? I have never seen any output from a scroll saw but had not expected a 3D decoration, very clever!
Terry.
Wizard9999
Postby Dalboy » 19 Oct 2015, 16:30
The decoration is looking good can't wait to see it all cleaned up and hanging.
Somewhere in all of my files I have a few patterns for these which like so many things I keep promising to make but end up doing something else.
In other words a long to do list that does not get any shorter
Dalboy
Postby Gill » 29 Oct 2015, 12:41
Thanks for sorting out the photos, Andy :eusa-clap: .
Terry, you simply take a square bit of 35mm stock and attach a pattern to it which is designed so that when you can rotate the stock through 90 degrees and cut straight through. It's easier to demonstrate with photos than it is to explain in writing. Next time I make one, I'll produce a step-by-step post with lots of photos (get ready, Andy :twisted: ) to show you how it's done.
Gill
Postby Wizard9999 » 29 Oct 2015, 13:47
Thanks Gill, that would be really interesting to see.
Wizard9999
Return to Scrolling
cron
