It is currently 05 Dec 2020, 12:21
Blade, speed, smoke …… Beech Reindeer
Postby Phil » 24 Dec 2019, 19:31
Ok, even the Guinea fowl are avoiding passing the garage on their way to the bush, can’t handle the blue air.
I decided to go back to basics and first recheck all the settings.
Check the oil in the top and bottom arms.
The top arm is a screw and washer. Hegner UK could only supply a grease nipple, so I improvised.
(33.91 KiB)
The bottom arm has the spring-loaded cap.
(31.68 KiB)
My oiling kit - special “wey ?” oil and a syringe.
(33.26 KiB)
The bottom blade holder was loose and the screw ‘thing’ too short. So needed to improvise and came up with a small bolt, wing nut, nuts and spring washers.
(14.63 KiB)
Then came the fitting and alignment.
Sawing the second half of the pattern went a lot better.
No broken blade but this one looks like it has had it!
(23.15 KiB)
Burnt Beech
(76.99 KiB)
Second half cut
(20.1 KiB)
Re: Blade, speed, smoke ……
Postby Gill » 24 Dec 2019, 20:24
Necessity is the mother of invention! :eusa-dance:
I like your hi-tech maintenance system.
Strangely enough, my saws both have loose-fitting lower blade holders. They're supposed to be loose in order to avoid stressing the quasi-pendulum motion of the blade as it cuts. Or have I misunderstood you?
Gill
Postby Phil » 25 Dec 2019, 07:07
Gill wrote:Strangely enough, my saws both have loose-fitting lower blade holders. They're supposed to be loose in order to avoid stressing the quasi-pendulum motion of the blade as it cuts. Or have I misunderstood you?
Gill, that was on my question list - how tight/close should those screws be?
Both just touch the little hole on top of the blade holder.
I will take the covers off the small Hegner tomorrow and see what that looks like.
Postby Phil » 29 Dec 2019, 11:03
Gill wrote:Necessity is the mother of invention! :eusa-dance:
Gill, the small machine bottom bracket is just a loose holder.
The Polycut blade holders are the same top & bottom - a screw fitting to hold it in place.
Re: Blade, speed, smoke …… Beech Reindeer
Postby Phil » 29 Dec 2019, 11:12
This is the last cut on the Beech Reindeer.
I wrapped it in clear packaging tape which worked a lot better than the brown stuff.
(30.34 KiB)
Completed! :lol:
(26.61 KiB)
These are the 3 offcuts which have been sanded. They will get a small eyelet for hanging, painted and a ribbon. Can be hung on a Christmas tree.
(20.02 KiB)
Postby Malc2098 » 29 Dec 2019, 12:00
Nice.
Postby Phil » 29 Dec 2019, 17:57
This one is from some Ash. Just a hard as Beech
(56.63 KiB)
The offcut for painting and hanging in the tree.
(23.21 KiB)
Postby Gill » 30 Dec 2019, 00:39
Congratulations, Phil - you've surmounted your difficulties and those deer look impressive. Well done!
Gill
Postby Phil » 05 Jan 2020, 18:20
Gill wrote:Congratulations, Phil - you've surmounted your difficulties and those deer look impressive. Well done!
Thanks Gill.
I will persevere ........................
Return to Scrolling
