It is currently 05 Dec 2020, 12:42
Serviette 'Rings"
Serviette 'Rings"
Postby Phil » 05 Jan 2020, 18:15
A fun project cutting some serviette rings for kids.
(Grandson & Granddaughter)
Some designs
(52.84 KiB)
Templates cut from 3mm MDF
(34.85 KiB)
First one a Dolphin
(31.07 KiB)
This one might be a doubtful starter, too many fragile cuts
(26.58 KiB)
Re: Serviette 'Rings"
Postby Malc2098 » 05 Jan 2020, 20:50
nice.
Postby Gill » 06 Jan 2020, 00:09
Looking good :) .
Make sure you retain substantial bridges on the wolf's tail where it joins the main body and you'll be fine.
Gill
Postby Phil » 06 Jan 2020, 17:48
Thanks Malc
Thanks Gill.
This is my first attempt at internal cutting.
Still need to get comfortable in the loosening of the blade to feed through the hole and getting the blade fitted straight again. Only broke 1 blade cutting the templates,
Changing blade sizes is easy - I have 2 sets of blade holders 8-)
Postby Andyp » 09 Jan 2020, 10:38
Well done Phil. If it were me I would take the easy way out and cut the inner circles that the serviete goes through with a forstner bit or similar.
Postby Phil » 09 Jan 2020, 19:33
Andy, that thought had crossed my mind. I have forstners big enough for that, but then it starts looking 'machine made'.
My forstners range from 10mm to 40mm. Expensive collection. :o
Postby Phil » 12 Jan 2020, 17:49
The first 4 cut and sanded.
Being crap-SA-Pine it requires a lot more sanding than a hardwood.
These will get the glue and water sealing.
(107.28 KiB)
Postby Phil » 02 Feb 2020, 10:50
The mouse, all the internal lines were cut with a #3 blade.
Mouse
(14.38 KiB)
The wolf actually was a lot easier to cut at the end of the day.
Cut around the outline of the all the sharp points, then go back and cut out the 'V''s
The internal small cuts with a #3 blade
Wolf
(21.29 KiB)
The menagerie so far
Menagerie - part 1
(44.91 KiB)
The DIL prefers the natural wood colour as opposed to them being painted with acrylics.
So they will just get some clear PU sanding sealer.
Postby Gill » 02 Feb 2020, 21:42
Those are so cool. Well done, Phil :) .
Gill
Postby Phil » 04 Feb 2020, 13:45
Gill wrote:Those are so cool. Well done, Phil :) .
Thanks Gill.
Postby Phil » 31 Mar 2020, 18:48
Some more templates.
Looking closely you will recognize Malc! :eusa-clap: :eusa-clap: :eusa-clap: :eusa-clap:
And it also looks like there is a baby Malc.
(41.5 KiB)
Postby Malc2098 » 31 Mar 2020, 21:26
:text-bravo:
:eusa-clap:
Thanks, Phil.
Postby Phil » 07 Jun 2020, 18:31
Here are some animals cut from Beech.
Looks good, clean cut, just needs sanding
(38.87 KiB)
But, don’t let the wrapper fool you!
The substrate is good ‘ol pine
(37.1 KiB)
I have some small pieces of Beech veneer, which I glued onto both sides of the pine.
My small veneer press
(35.81 KiB)
Veneer glued and pressed
(32.45 KiB)
Pattern drawn ready for drilling and the the saw.
(24.56 KiB)
The back had a coat of glue+water mix to seal. Less fluffy burrs.
Postby Malc2098 » 07 Jun 2020, 19:14
Nice.
Return to Scrolling
