It is currently 29 Mar 2024, 13:11
Keep this one to yourselves.
Postby Mike G » 14 Jul 2015, 20:02
Some while ago I mentioned an unusual house I am designing. Well, here it is.
This is the concept model:
The rationale is that the site had a windmill on it many years ago (there is no sign of it now), and the owner wanted something that rotated, and reflected the idea of the windmill. Well, that's a bit too literal for me, so I came up with this turbine-like shape which implies rotation but without actually looking like a windmill or turning at all.
The site is in what is colloquially known as green belt (protected from development). There are only very limited things you can build on protected land, one of which is the so-called paragraph 52 development, for "innovative and exceptional" houses. These have to be virtually self sufficient on the site to start with, but also have to be extremely special houses. You can't just stick up a grand pseudo-Georgian mansion under this rule. It is so rare that this local authority have never done one before, and had to consult with other authorities to understand what is involved.
Anyway, the client and local authority liked the concept model, and a structural engineer got really excited (curved in 2 dimensions glulams are extremely rare), so we are pressing on. I've drawn it on the computer in 3D, but this isn't an awful lot of use to anyone. I couldn't get access to a 3D printer, so I retired to the workshop for a couple of days to make a better model.
The big curved glulams are the difficult bit. Curving in 2 dimensions means it is very difficult to keep a reference when trying to cut them out. I laminated some ply, cut the top shape, and then stuck a temporary platform over that with the plan shape glued to it:
After each cut, I glued everything back together again with hot-melt glue, then took another cut:
In comparison, the central ring was dead easy. In reality this will be 4.8 metres in diameter (16 feet or so). This model is at 1 to 50:
Then I made the basement and the site (the plot is about 20 metres wide and about 200 metres long in reality, so the model only covers the part of the site with the building on it):
But fouled it up completely, and remade it:
With the ground floor in place:
With the glulam sole-plate in place:
A bit of cardboard and hot-melt glue for the ground floor plan:
Then it was time to assemble to frame:
But there's only 3 legs, Mike. Yep, that's because I'm a clumsy bugger:
There'll be 4 when the glue dries. I then glued those legs to the sole plate:
Note the very different shape to the original concept model. I have made the ribs a quite different curve, so that they get up higher quicker, giving the building greater capacity, particularly upstairs on the 1st floor (I'm not sure........do Americans call upstairs the second floor?). I have also simplified the internal walls because everyone kept telling me that curved internal walls would mean spending a fortune on hand-made fitted furniture (.......yes, and......?).
More tomorrow, I hope. This is why I have nothing to report on my house build at the moment, but this project is important, might end up on TV, and you have to earn a crust. :D
Re: Keep this one to yourselves.
Postby tracerman » 14 Jul 2015, 20:34
Mike G -
1) Crikey .
2) Do we sense Kevin McLoud somewhere here ?
Steve
tracerman
Postby Mike G » 14 Jul 2015, 20:49
There'll be a serious discussion about Grand Designs once we have Planning Permission.
Postby Rod » 14 Jul 2015, 21:51
Interesting stuff - is it going to be covered with some sort of fabric?
How will it be insulated etc?
I watched one of those GD programmes that built a house according to Paragraph 52 - very difficult to comply with it.
They managed to reach the required no. of points by doing some "green" landscaping.
Postby Robert » 14 Jul 2015, 22:05
I watched a BBC programme about Frank Gehry a few weeks ago and his designs with nothing straight and using aircraft design software to cope with the curves.
Hope your software is up to this design. Most impressed. I've done difficult 3d curved shapes in sheet metal in the past, sometimes taking on work our competitors baulked at so I know how hard it can be to get things right when complex curves are involved. Looking forward to the grand designs episode one day.
Postby RogerS » 14 Jul 2015, 22:20
In awe.
Postby Mike G » 14 Jul 2015, 22:26
Rod wrote:Interesting stuff - is it going to be covered with some sort of fabric?
Thanks Rod. The initial conversations were around covering it in sheet metal....zinc or copper, but I have come to the view that it will be better covered with plain tiles, and with major copper highlights (like a capping over the ribs, and around all the windows, plus the rainwater goods). One of the problems with trying to cover in a sheet material such as zinc or copper is that they need a ply substrate, and trying to cover that building with ply will be a real test.
It can't be done in a tensile material because of the valleys. Well, let's rephrase that. It could be done, but it would cost a small fortune.
Postby Mike G » 14 Jul 2015, 22:28
Robert wrote:....Hope your software is up to this design. Most impressed......
Thanks Robert. Yeah, it's laborious in Autocad, but it is do-able. I'm quite good at 3D modeling.
RogerS wrote:.....In awe.
Cheers Roger.
Postby Wizard9999 » 14 Jul 2015, 22:49
Any thoughts on the build cost Mike?
Terry.
Wizard9999
Postby Mike G » 14 Jul 2015, 22:52
I told the client to have a million pounds available. The basement alone will cost more than £200,000.
Postby chataigner » 15 Jul 2015, 07:51
Once again I'm utterly dumbfounded. Firstly by the vision and creativity, but also by the knowledge that the architect is quite busy with another project at the moment !!!
Hope it comes to fruition, it looks amazing.
Cheers !
http://www.rue-darnet.fr
chataigner
Postby Mike G » 15 Jul 2015, 10:06
Thanks David.
Postby Mike G » 15 Jul 2015, 21:42
I got a few hours in on the model this evening. First, I did another 4 curved-in-two-dimensions glulams. The upper photo shows the pieces prior to the final cut:
The area below the glulams will be glazed:
These secondary timbers took forever! Each one had to have a plumb cut and a seat cut, and an angle to one side or other of the plumb cut.......and had to be adjusted multiple times to get the length right:
You'll note that I only did alternate ones on the left hand side. I was getting short of time, and I'll fill in the gaps tomorrow.
Postby DaveL » 15 Jul 2015, 21:58
Well this looks good, but you will definitely need help building this, unlike your current project. :lol:
Regards,
DaveL
Postby Mike G » 16 Jul 2015, 19:16
I finished off the rafters:
It took some while to work out the shape of the upstairs floor, but having done that, it was only a few minutes with a glue gun and knife and we had an floor layout done:
It's handy to have a bed to scale to give a sense of the size of the rooms.
Next came the solid oak stair :) :
The last photo shows that I cut a front door through the sole plate.
Postby Pinch » 17 Jul 2015, 06:49
This is very cool 8-) Right up my street - no puns.
Looking forward to seeing this one develop Mike - exciting! 8-)
Pinch
Postby Wizard9999 » 17 Jul 2015, 10:09
Mike G wrote:I told the client to have a million pounds available. The basement alone will cost more than £200,000.
Mike
So, based on my rule of thumb for Grand Designs that the actual cost comes in at twice what the architect says at the outset, that'll be two million then. I am sure that this tendency has nothing to do with architects wanting to get their wonderful creations built and therefore don't want to scare clients off with two big of a cost to start with. ;)
Terry.
Wizard9999
Postby Rod » 17 Jul 2015, 11:09
Twice as much and twice as long - but that's mainly when the Client manages the project themselves?
I'm sure it won't happen if you keep control Mike.
Postby Mike G » 17 Jul 2015, 18:35
It's rather the other way with me, Terry. I would rather scare them off starting something they can't afford.
Postby Mike G » 17 Jul 2015, 19:13
I built the dome quickly:
I think it's probably too tall, but it's good enough for the purpose of discussion at this stage.
Postby RogerS » 17 Jul 2015, 21:58
I preferred it without the dome, TBH. Looks a bit like a modern cathedral now, IMO.
Postby Mike G » 17 Jul 2015, 22:50
Yeah, I'm going to have another go at that........
Postby chataigner » 18 Jul 2015, 17:37
RogerS wrote:I preferred it without the dome, TBH. Looks a bit like a modern cathedral now, IMO.
:text-+1:
Cheers !
chataigner
Postby Mike G » 18 Jul 2015, 20:53
I had another go at the dome. It's better, but I think I'll end up with more of a lens shaped glass clover over the occular.
Next
Return to Projects & WIP
