It is currently 29 Mar 2024, 09:35
Rod wrote:What size timbers are you using and are the side sole plates sitting directly on the slab base?
PearlJammer wrote:How would the water get in, it's on a 6" base? The finish will be ship lap past where base meets frame.
Lee
Rod wrote:It's not clear from the photo (to me) but if the 6" base is sitting above the slabs/ground then you have effectively created a plinth so that would've ok?
PearlJammer wrote:Thanks Mike for your comments. So just to clarify, a solid piece of 4x4 across a 4m span will not be ok with out support from above. Some pics of the area for reference.In the next post
Lee
Users browsing this forum: wallace and 16 guests
