Rod wrote:Looking good
Cheers Rod
It is currently 29 Mar 2024, 02:52
Wizard9999 wrote:Looks really good. Inspires me to want to get good at this woodworking lark .
Terry.
Andyp wrote:Gorgeous
9fingers wrote:Is there a reason (technical one rather than just tradition?) why doors are assemble with horns on and immediately cut off.
I fully accept that my methods are unorthodox but I make a door/panel etc from components cut to exact sizes and assemble square & true so all it should need is a minor fettle to fit the opening. If the opening is not a rectangle I make a template and use that to dimension from.
I'm curious to understand.
Thanks
9fingers wrote:Thanks for the reply Paul.
I can appreciate the protection that the horns offer if you are making a batch of doors keeping the stile end from damage until ready to fit. Also ready made doors get protection from maker to merchant.
However the moment you come to fit a door, the horns have to at least come off the bottom so it can be offered up, marked and attacked with a plane.
Tusses wrote:Hi Paul
I was surprised to see you only morticed the hinges into the door, and not the case.
I was told the mortice adds support to the hinge, and make the over all thing stronger ?
I guess you know from experience when this is needed or not ?
Rich
Pinch wrote:
Cheers Rich, yes, the leaf of a butt hinge will add some resistance to gravity and I wouldn't do this with a normal sized heavy door. This cabinet door is lightweight and letting the hinges like this used to be common practise.
Tusses wrote:the final fitting looks excellent !!! as usual
Maybe you ought to think about doing this for a living ??
did you swap the bright posidrive screws for slotted brass ?? :-P
Rod wrote:Really nice work - the client must be well pleased.
Wizard9999 wrote:
Last question is having pulled back the carpet is it down to you to cut and refit it?
Terry.
