It is currently 28 Mar 2024, 16:27
Bespoke fitted Oak Book & Display Case (FINISHED)
Re: Bespoke fitted Oak Book & Display Case (FINISHED)
Postby Jimmy Mack » 19 May 2016, 19:33
Looks smashing Pinch...I was going to reward you with a picture of the Wacky Jackie's mannequin ...but whilst on route for a well earned pint last night...she (the mannequin) wasn't there to snap! Perhaps an outfit change?
There was however the village phone box...will that do? Logo a bit out of date...amongst other things :D ...Oh and it say's 'Phonecard only -NO coins' :lol:
Jim
Jimmy Mack
Postby Pinch » 21 May 2016, 11:28
DaveL wrote:Nicely described, I think that really finishes the job off as a classic piece.
Cheers Dave 8-)
Pinch
Postby Pinch » 21 May 2016, 11:31
Mike G wrote:Nice, Paul.
I'm not a fan of art deco (although I designed the interior of a 90m super-yacht in art deco style some years ago). Cover the top of your piece up, and the rest doesn't say "art deco" at all (which is a positive for me, as I said). I wonder in hindsight if you might have added a motif to the door panels, or done that layered thing to the stiles and drawer fronts which was typical of art deco?
Cheers Mike. Wow, that sounds like it was an interesting project. Yes, I did consider adding more Art Deco features, but the clients wanted to keep it low-key. The door panelling as you mentioned would have been very nice. 8-)
Pinch
Postby Pinch » 21 May 2016, 11:32
Newbie_Neil wrote:Paul,
I really enjoy your WIPs, as your work is always so good. Thank you for taking the time to post.
This must be the least "quirky" piece that you have ever made. :lol:
Neil
Cheers Neil, yes, indeed :lol: more quirky stuff please. 8-)
Pinch
Postby Pinch » 21 May 2016, 11:33
TrimTheKing wrote:Very nice work as always Paul.
I'm with Mike with AD not being a favoured style of mine but the workmanship, quality and fitting are just as we come to expect from your good self. :eusa-clap: :eusa-clap:
:text-bravo:
Cheers Mark, well, you know, one tries :eusa-whistle:
8-)
Pinch
Postby Pinch » 21 May 2016, 11:43
Halo Jones wrote:Lovely work. Could you describe how you get such accurate scribing? This is something I always struggle with. I always get it close but nothing near as nice as in your photos!
Cheers Halo. Yes, of course... There are a few ways to scribe and there are so many different scribes as well - skirting boards, coving, walls, ceilings, floors etc... An out-of-plumb straight or bumpy wall for example; I would normally use a compass to mark the scribe. Once you know how much material you are removing, offer the work against the wall ensuring it's plumb and level; then open your compass to the correct width and literally run the compass down the wall so the pencil (or lead) is marking the cut line on the work. You can also use the compass for the coving, but this is much more tricky as it's imperative you keep the compass perpendicular to the scribe at all times (including down the wall), otherwise your scribe won't be accurate. I also use a square or small rule to mark the datum points IE: corners of the coving etc.
Hope this all makes sense.
I'll open a thread and do a proper WIP with photos.
8-)
Pinch
Postby Pinch » 21 May 2016, 11:44
chataigner wrote:Lovely work, looks terrific. :eusa-clap: :eusa-clap: :eusa-clap:
Thanks also for the detailed fitting WIP, something I tend to struggle with, so very helpful to see how you do it.
Cheers David, glad it might be of some use 8-)
Pinch
Postby Pinch » 21 May 2016, 11:48
Wizard9999 wrote:Top notch! No wonder they are delighted.
Plus one for the scribing question. Also, a couple of posts back you said about marking the position of pilot holes for the hinges on the cabinet itself. I guess in this instance with no glass it was easy to do, but any tips on doing it with a solid door.
Last question is having pulled back the carpet is it down to you to cut and refit it?
Terry.
Cheers Terry, yes, exactly the same way. If hanging a full size door, approach the door into the hanging edge so that the bottom corner of the door is further in to the lining, then cock the door over so you can effortlessly line up a top hinge pilot hole and get a screw started. Then pull the door out and line up a bottom hinge pilot hole and all should be good. Hope this makes sense.
The carpet is the client's responsibility. 8-)
Pinch
Jimmy Mack wrote:Looks smashing Pinch...I was going to reward you with a picture of the Wacky Jackie's mannequin ...but whilst on route for a well earned pint last night...she (the mannequin) wasn't there to snap! Perhaps an outfit change?
Jim
Hahaha! Cheers Jim. 8-)
Looks like my father's greenhouse :lol:
:text-bravo:
Pinch
Postby Rod » 21 May 2016, 13:28
Village phone boxes - ours went years ago!
Is that a sycamore taking root?
Postby Halo Jones » 23 May 2016, 10:23
I'm pretty sure these are the two bits that I struggle with!
I am never so far out that I can't just add a little bit of caulking to make it look fine but I would like to raise my game a bit. Looks like I just need more practise!
Halo Jones
Postby Tusses » 23 May 2016, 17:34
If you struggle ..
Scribe to a piece of Card or something, until you get it perfect, then just transfer the shape to your work.
Tusses
Postby Pinch » 13 Aug 2016, 20:00
I popped in to see these peeps last Thursday to measure up the other fitted case for the living room. While I was there, I took a photo of the recent oak case which is now earning its keep.
It's always nice to see one of your jobs settling into its new resting place and doing what it was designed to do.
Beer night tonight - again! :lol:
:obscene-drinkingcheers:
:text-bravo:
Pinch
Postby Malc2098 » 13 Aug 2016, 20:13
Tasty!
Postby Rod » 13 Aug 2016, 23:14
Very nice
Postby Pinch » 15 Aug 2016, 18:41
Thanks chaps. 8-)
Pinch
Postby TrimTheKing » 16 Aug 2016, 10:39
Looks great in situ.
Postby Doug » 18 Aug 2016, 19:27
Very nice Paul :eusa-clap:
Doug
Previous
Return to Projects & WIP
Users browsing this forum: No registered users and 24 guests
