Fitted the ebony plugs today. To make sure they all line up correctly I decided to make some little jigs in MDF that locate against the edges of the carcase and doors respectively, then drilled the jigs for the hole locations so i could reproduce each position accurately. The jigs were designed to be revesible so that left and right sides match exactly. Heres the result :
I'm a bit undecided about what to use for a door handle, so made this mock up in scrap quickly on the BS, and fitted it with one screw. I've decided I quite like the idea of mimicing the cloud lifts in the muntins etc, but that it's too big. Will make a scaled down version tomorrow and try that. If it looks right, I could make the real ones with an ebony spline set into the back.
Then again... the media cabinet which will be in the same room, had solid ebony bar as handles - might go for that...?
It would create another design link between the two pieces.
