It is currently 29 Mar 2024, 08:27
Tusses wrote:Consider a vertical panel cutting Jig for breaking down full sheets up against the wall :-)
Rod wrote:Beef up your bench or make a new one with a woodworkers vice.
Make some stacking saw horses.
Buy tools as you need them and buy the best you can afford.
I still use a B&D circular saw I bought 30yrs ago and straight pieces of timber as a guide with some clamps to cut sheets down.
Woodbloke wrote: The bench is also your primary and most important tool; without a decent one you'll still be able to build stuff, but not as easily or enjoyably - Rob
9fingers wrote:Hmm!
I don't have a bench as such, but like tusses, i have a decent outfeed table.
I did buy a couple of vices but have not found the need for them and they are dumped under the RAS.
I do have a couple of planes but can't see how to plug them in so they done see much action.
Now chisels are used to scrape glue squeeze out from internal corners and a not so sharp one is good for scraping dried glue off the outfeed table But if you machine joints properly they dont need adjusting with a chisel
So Rob there is nowt wrong with your way of woodworking and you turn out excellent stuff but it is not the ONLY way to work wood.
woodstalker wrote:Bob, just downloading it now.
Tusses, thanks very much looking forward to seeing it.
Found this one a guy made for a few pounds on youtube:
Edited to try and make link work:
[youtube]cu5UU10F7NQ[/youtube]
https://youtu.be/cu5UU10F7NQ
Any ideas why the "YouTube" function thingy doesn't work for me?
MOD Edit (TrimTheKing) : I've fixed it for you, the only bit you need in between the tags is the random number/letter sequence at the end of YT links. In your case, this bit "cu5UU10F7NQ". Cheers.
TrimTheKing wrote:woodstalker wrote:Bob, just downloading it now.
Fixed for you, see above.
Woodbloke wrote:9fingers wrote:Hmm!
As ever, horses for dooberies, but your's is an engineering approach whereas I come at stuff from a different perspective. The bench allows me to use hand tools on parts of a project where it's extremely difficult or almost impossible to achieve the same result with machines alone:
Detailed rasp and shaping work on the leg profiles, 'Birds Mouth' mortise and tenons, wedged, raised and profiled mortise and tenons in the leg; shaped and made with a Jap paring chisels, shaped and fitted cross rail. All almost impossible to do without a proper bench, hand tools and the holding facilities that a good bench provides - Rob
