It is currently 28 Mar 2024, 21:20
by Andyp » 05 Dec 2016, 21:03
Here's one a made a few years ago.
oak with a walnut inlay in the top
Come on Terry, show us yours
- Petrified Pine
- Name: Andy
by Pinch » 05 Dec 2016, 21:40
Nice box Andy! Very cool indeed.
Pinch
- Old Oak
- Name: Paul
by Tusses » 05 Dec 2016, 22:14
Nice :-)
I need to try the corner spline thingy !
Tusses
- Old Oak
- Name:
by meccarroll » 05 Dec 2016, 23:14
Tusses wrote:Nice :-)
I think they are walnut slithers, Rich
Very nice box Andy, bit more to it than you are making out though
meccarroll
- Sapling
- Name:
by Commander » 06 Dec 2016, 05:04
That's a good looking box Andy, I very much like those splines, they look slick and would be rather a bit easier to make then some of the more fancy joining techniques, so something I can try!
Commander
- Sapling
- Name: Erich
by Phil » 06 Dec 2016, 07:19
Commander wrote:That's a good looking box Andy, I very much like those splines, they look slick and would be rather a bit easier to make then some of the more fancy joining techniques, so something I can try!
Andy, what is the black line across the top?
Erich, the cutting part is easy with a jig for the table saw, it's the trimming off afterwards of the bits sticking out and not damaging the box.
- Old Oak
- Name: Phil
by Andyp » 06 Dec 2016, 09:04
Pinch wrote:Nice box Andy! Very cool indeed.
Thanks Paul, it wont stand up to a closer inspection mind.
- Petrified Pine
- Name: Andy
by Andyp » 06 Dec 2016, 09:06
They were made on the table saw with the box clamped to a lump of 4x2. Make sure you use a blade that has the teeth FTG, flat top ground, or you will get a V shaped groove.
- Petrified Pine
- Name: Andy
by Andyp » 06 Dec 2016, 09:09
meccarroll wrote:Tusses wrote:Nice :-)
Thanks Mark, simple angled cut on the TS. Cutting the slices of walnut for the top was the hardest part.
- Petrified Pine
- Name: Andy
by Andyp » 06 Dec 2016, 09:11
Thanks Erich, like everything else accuracy is key. I actually think it is easier to make close fitting dovetails than accurate mitres. As I said above make sure you have a FTG saw blade to make the grooves for the splines.
- Petrified Pine
- Name: Andy
by Andyp » 06 Dec 2016, 09:13
Phil wrote:Commander wrote:That's a good looking box Andy, I very much like those splines, they look slick and would be rather a bit easier to make then some of the more fancy joining techniques, so something I can try!
Phil, that is just a natural grain in the wood. Here is a shot of the top.
- Petrified Pine
- Name: Andy
by Pinch » 06 Dec 2016, 12:06
Very nice inlay with the oak there chap. You mentioned it's walnut - is it a two leaf burr walnut inlay? I do like oak and walnut together.
Pinch
- Old Oak
- Name: Paul
by Rod » 06 Dec 2016, 12:06
Here's a jig I made
- Old Oak
- Name:
by Andyp » 06 Dec 2016, 13:04
Pinch wrote:Very nice inlay with the oak there chap. You mentioned it's walnut - is it a two leaf burr walnut inlay? I do like oak and walnut together.
As I say, don't look too closely. It is actually 4 pieces and not from a burr just cut from the end of a lovely piece of figured walnut that a local UKW forum member gave me many years ago.
I agree with you about oak and walnut. I find walnut very easy to work with and very easy to get a very good finish on.
- Petrified Pine
- Name: Andy
by Phil » 06 Dec 2016, 13:05
Yes, I see. Nice looking box and insert.
- Old Oak
- Name: Phil
Return to Projects & WIP
Users browsing this forum: AndyT and 14 guests
