It is currently 28 Mar 2024, 22:12
Storage unit
Storage unit
Postby Doug » 06 Sep 2017, 17:12
I've been using mini systainers for a year or more very since I was given a couple, they are 265x170x70mm in size & ideal for bits & pieces that I need both on site & in the workshop. They clip together which makes them easy to transport especially when carrying several & saves me having 2 lots of tools like sharpening kit, sanding & finishing gear etc for both the van & the shop.
Having recently acquired some more as they were on offer I figured it would be a good idea to make a storage unit for them & as I was over at Jonny D's the other day I took up his offer of cutting & edging some MFC while I was there.
He had some nifty shop made cauls which have a groove to hold the 2mm lipping with upstands to centralise the panels when gluing & clamping the trim to the panels
(379.47 KiB)
A close up of the caul,
(265.07 KiB)
After an hour in clamps the panels were removed & the edges cleaned up with his laminate trimmer.
(305.21 KiB)
Back at my shop it was simply a matter of dominoing the shelves referencing the slots off the bed of the planer & utilising the dominos built in guides
(351.09 KiB)
The corresponding slots in the sides of the unit were cut using a spacer with reference marks to guide the cutter
(321.35 KiB)
The unit was then glued & clamped together
(370.66 KiB)
Once dry the back & top were screwed in place, the unit is small enough to sit under the pillar drill utilising space that would otherwise be wasted.
(295.24 KiB)
Doug
Storage unit
Postby TrimTheKing » 06 Sep 2017, 17:31
Oh bravo Doug! Colour schemed and everything!
Re: Storage unit
Postby Rod » 06 Sep 2017, 17:40
Nice - Like the green
Re: Storage unit
Postby Doug » 06 Sep 2017, 18:37
TrimTheKing wrote:Oh bravo Doug! Colour schemed and everything!
Rod wrote:Nice - Like the green
Cheers, re the colours, I like to give my mates plenty of ammunition :lol:
Doug
Re: Storage unit
Postby jules70 » 06 Sep 2017, 21:59
Very nice. I like that a lot !
jules70
Re: Storage unit
Postby Andyp » 07 Sep 2017, 07:21
Too posh for my 'shop. But very nice indeed.
Re: Storage unit
Postby Tusses » 07 Sep 2017, 15:06
Very good Doug :obscene-drinkingcheers:
Tusses
Re: Storage unit
Postby Doug » 07 Sep 2017, 21:24
Cheers chaps.
I'm pleased with how it turned out, more because this is the first time I've used cold glue to apply edge banding & it's worked very well so opens up more options :eusa-think:
Doug
Re: Storage unit
Postby Jimmy Mack » 10 Sep 2017, 11:07
Hi Doug, What adhesive did you use?
How is it pulling the systainers out, do you push them from the back?
Looks very tidy.
Jimmy Mack
Re: Storage unit
Postby Doug » 10 Sep 2017, 12:55
Jimmy Mack wrote:Hi Doug, What adhesive did you use?
Looks very tidy.
The adhesive was kantol from Ostermann.
https://www.ostermann.eu/en/product/red ... -greenline
The systainers come out easily by pulling on the front green turn catch, (you can't tell from the photo but I fixed a back to the unit) though being the mini ones there's no weight to them, I went for the drawers for my main systainers as I figured a unit like this wouldn't work as well with those
Doug
Return to Projects & WIP
Users browsing this forum: fiveeyes and 13 guests
