It is currently 28 Mar 2024, 21:57
Jimmy Mack wrote:Hi Bob,
It's the same cheap blue stuff Rod has from Toolstation, it's got enough of a stretch IMO, I think if there's too much power here the veneer may buckle, it doesn't need a lot of force, if you need more...you might need to reshoot your edges.
'Frog tape' would be stretchier and it's adhesive has a longer open time. It's more expensive and I get through loads of the blue stuff. I like to get the tape off as soon as, usually the next morning, I suspect with purpose made veneer tapes there will be promises on the quality of the adhesive and not upsetting finishes, I've not had a problem here - yet!
HTH
My hanging hand tools are just for show......shhh....don't tell anyone9fingers wrote:Jimmy Mack wrote:Hi Bob,
HTH
Thanks Jim,
I doubt buckling will be a problem with construction veneers that I'm using. Incidentally, Woodbloke's method for shooting is not as I expected with a hand tool but to clamp between known straight edges and rout it with a bearing guided cutter. Rob's finally getting the hang of machinery these days
I wasn't too sure at first but it's surprisingly strong. I can dangle a sheet of four leaves vertically and happily brush off any debris before laying.Andyp wrote:
so you applying glue to the edges of 1mm thick veneer. I would have thought that when you removed the temp tape and flipped it over the joint would have failed - even if being held by tape on the other side. Fascinating.
Thanks chappiePinch wrote:Hey Jim, good show matey. Glad to see you're on the case. (No pun intended).
This is such a classy cabinet - loves it I do!
Mike G wrote:Oooh, tasty! You must have been supremely confident in that block plane to put it anywhere near the veneer. I know, you were just trimming up the edge, but still.....
Rod wrote:Looking good - how long did that take to cut - must have saved a great deal of time?
What are you going to blacken it with or are you using “black” wood for the real thing?
How very dare you.......Andyp wrote:I think that is cheating. very clever though. Are those pegs in the end to make sure the piece is correctly orientated when it is turned over?
Hi Mike....The grey is a pre-dyed bird's eye maple, veneer.Mike G wrote:Where does the grey colour come from?
Users browsing this forum: canoemoose and 14 guests
