It is currently 28 Mar 2024, 20:23
Clamp rack & charging station
Postby Doug » 14 Dec 2017, 08:36
Hopefully over the holidays I’m going to try & get a little more organised in the workshop, to this end I’ve made a start on a clamp rack & unit for battery chargers.
The rack was made from a piece of aluminium angle with 1/4” slots milled at 1 & 1/4” centres, I was going to paint the angle but after cleaning it up with some webrax it came up quite shiny
(328.32 KiB)
Once fitted to the wall I was pleased I hadn’t bothered painting it as it’s almost invisible
(213.95 KiB)
For the unit I used the black MFC & 2mm green edging I’d used previously in the year when I made a unit for some mini systainers.
(245.61 KiB)
I’ve added doors as this is quite close to the lathe so hopefully stray wood shavings & dust will be kept to a minimum around the chargers
(261.71 KiB)
Doug
Re: Clamp rack & charging station
Postby Mike G » 14 Dec 2017, 09:32
Aluminium oxidises at the drop of a hat. It won't stay shiny long. As you say, though, it's all but invisible.
Postby Malc2098 » 14 Dec 2017, 10:41
Neat!
Postby Andyp » 14 Dec 2017, 13:40
Being as you have not left room for expansion on that rack can we assume you have enough clamps :)
Postby Coley » 14 Dec 2017, 14:25
Now that is tidy !!
Coley
Postby Rod » 14 Dec 2017, 19:49
Very nice
Postby TrimTheKing » 15 Dec 2017, 15:43
:text-bravo: :eusa-clap:
Return to Projects & WIP
