It is currently 28 Mar 2024, 21:06
Robert wrote:Looks a nice quality expensive ply that you've used for that former. Guess you are going to be making a lot of guitars then?
Seriously though from what I've seen so far it should be a quality job. Looking forward to seeing it as it progresses.
RogerS wrote:I'm missing something here, Malc. If you've already got those sides, why do you need that mould ?
Malc2098 wrote:RogerS wrote:I'm missing something here, Malc. If you've already got those sides, why do you need that mould ?
Everything will be in tension, the sides, the back, the soundboard, and the neck when strung. That's what gives the acoustic guitar its sound.
Pinch wrote:Very nice Malc.
Is every component you need for the build in the kit, down to the actual finish?
Andyp wrote:I am looking forward to the live streamed concert when finished.
RogerS wrote:oooh..if that had been me, the air would have been blue. Good recovery. Is it worth sticking veneer tape across the ends to try and prevent this from happening again ?
Malc2098 wrote:RogerS wrote:oooh..if that had been me, the air would have been blue. Good recovery. Is it worth sticking veneer tape across the ends to try and prevent this from happening again ?
If I had veneer tape I might have thought about it, but I quickly went into glue the rim together with the end blocks which I've been doing, including there dry runs for the last hour.
Later in the build there's a point where you glue strips across the insides of the sides to prevent splits when it's tensioned up as a whole body.
DaveL wrote:That's a neat solution. One of the things I have made for making the bass is radiused sanding block for the fret board.
RogerS wrote:I envy your patience and skill, Malc.
Also your clean floor.
Users browsing this forum: Malc2098 and 16 guests
