It is currently 29 Mar 2024, 16:36
Andyp wrote:Roger, what is holding that scaffolding down? Presumably when you get a tarp on the type of breezes you get up there will just get underneath it.
Andyp wrote:On that basis Roger why do high sided vehicles get blown over? I hope you are right and with the usual caveat of me knowing nothing I would try and anchor that scaffold if it were me.
Andyp wrote:Well I sincerely hope you are right.
Mike G wrote:Forget the orangery, Roger. It's obvious you should be building a windmill!
9fingers wrote:...
I presume the lantern is coming as a kit of parts for assembly in situ then rather than craned into place?
RogerS wrote:9fingers wrote:...
Built by my own fair hands.
Andyp wrote:It's going to be like a greenhouse in there, if the sun ever shines.
Malc2098 wrote:That was wicked of me, above! Bad Malcolm!
Can you put any constructional timber, 2 x 2 , 3 x 2, 4 x2, anything you've got laying around, above the scaffolding tubes but below the tarp to make smaller squares with less water collected, or even allowing the tarp to straighten out.
Users browsing this forum: No registered users and 28 guests
