It is currently 29 Mar 2024, 12:54
Happy Birthday... Maybe ?
Re: Happy Birthday... Maybe ?
Postby Jimmy Mack » 17 Nov 2018, 14:24
RogerM wrote:Looking really good. When you seal the sycamore to stop the ebony dust contamination, doers subsequent sanding remove the surface finish ready for whatever your final finish is going to be, or is it part of the permanent finish?
Thanks Roger, yes subsequent sanding does remove the surface finish, it still gets in the Sycamore grain , a grain fill would be best prior perhaps Sanding with extraction helped the most, I've the Mirka /Abranet sanding block which you can plug into the vac. I use the Abranet on the ROS too.
Jimmy Mack
Postby Jimmy Mack » 17 Nov 2018, 14:28
PS... same finish throughout* I'm brushing the Osmo UV Wax (WB), hoping the UV blockers will delay the effects of UV for as long as possible. Some maple finished the same way 3 years ago still looks quite light .
*Except the scorched Oak which is ebonised plus extra thin oil
Jimmy Mack
Postby Rod » 17 Nov 2018, 16:54
Really nice work
Postby Andyp » 17 Nov 2018, 17:01
Indeed. Gorgeous.
Postby Jimmy Mack » 21 Nov 2018, 14:47
Front legs: black. In the OP I drew them to the edge... But now I'm not too sure...
Middle or Edge?
Jimmy Mack
Postby DaveL » 21 Nov 2018, 18:51
Not that I know much about designing furniture, but I like the leg in the middle better than on the edge.
Regards,
DaveL
Postby Malc2098 » 21 Nov 2018, 18:54
DaveL wrote:Not that I know much about designing furniture, but I like the leg in the middle better than on the edge.
:text-+1:
Postby Andyp » 21 Nov 2018, 19:37
FWIW I disagree and think the edge is better. Would like to see the whole front with both legs in situ.
Postby MY63 » 21 Nov 2018, 21:53
I Think it looks fantastic not sure where the legs should go.
MY63
Postby RogerM » 21 Nov 2018, 22:05
Looking fabulous. I think I prefer the leg in the corner. If it was in the middle, it will only look as though it's in the middle when viewed straight on anyway. But Hey! I'm no design guru!
RogerM
Postby Jimmy Mack » 21 Nov 2018, 23:41
Oh.... 50/50.
I'm not sure the plates or soffit are going to be stiff enough and my legs are quite slender...I might need to work in an apron or rake to eliminate twist/wobble which will lead the leg position (possibily outside)...
Jimmy Mack
Postby Rod » 22 Nov 2018, 00:24
Outside for me as original sketch
Postby Jimmy Mack » 25 Nov 2018, 17:15
I tried out the round legs but they were just too skinny and wobbly Image
Trialed a few alternatives...
Settling on ..
If you can make sense of it upside down!... Along with a cardboard mirror template...ImageImage
A free hand template out of some scrap panel an elliptical router jig would be ideal... But the clock is ticking!... So a bit of sculpting... Image
Cutting off the bulk of the inside waste and corners for glue up ..
Deadline looms!
Onward
Jimmy Mack
Postby Malc2098 » 25 Nov 2018, 18:00
The scale and positioning of the round legs looks just right to me; very 60s.
Is there any way you can brace them?
Postby Jimmy Mack » 25 Nov 2018, 18:06
Malc2098 wrote:The scale and positioning of the round legs looks just right to me; very 60s.
I thought they were a touch too skinny myself... Keeping the round leg design would have been nice tho. A curved stretcher would do it but the form work and into a taper felt a little envolved, perhaps in conjunction with an apron also... Maybe next time
Jimmy Mack
Postby RogerM » 25 Nov 2018, 18:11
Actually Jimmy, just to be helpful I like the square section you have shown, with the triangular brace under the drawer. To my eye at least the round ones look too spindly. Fine perhaps for a consol table, but not for something more substantial. Might tapering the square leg improve it further?
Sent from my ONEPLUS A5010 using Tapatalk
RogerM
Postby Jimmy Mack » 02 Dec 2018, 17:51
RogerM wrote:Actually Jimmy, just to be helpful I like the square section you have shown, with the triangular brace under the drawer. To my eye at least the round ones look too spindly. Fine perhaps for a consol table, but not for something more substantial. Might tapering the square leg improve it further?
Thanks Roger not sure if it's too heavy... Though the scorching will create a slimming effect. I've tapered the leg but to just one face (side view)
Jimmy Mack
Postby Jimmy Mack » 02 Dec 2018, 18:03
A few catch up shots...
Legs
Initially I made the stool a bit too small imoImageImageImage
So I extended it using the insert (note glass) as a design clue. I drew half the shape on some 3mm ply, hand shaped and used this to template route the maple from. ImageImage
Taper jig
Buttons...
Stool topImageImage
Scorched and ebonised components
Getting closer...
I've a soft, black suede seat to make... Then I'm almost there
Jimmy Mack
Postby DaveL » 02 Dec 2018, 19:41
I like the rectangular legs much better than the spindle ones, looking very nice.
Regards,
DaveL
Postby Rod » 02 Dec 2018, 22:01
Looking good
Postby Malc2098 » 02 Dec 2018, 22:03
Can't wait!
Postby RogerM » 02 Dec 2018, 23:41
I like that. Very much in keeping with the rest of the piece. Looking forward to seeing how this turns out.
RogerM
Postby Jimmy Mack » 03 Dec 2018, 18:25
Here's the seat, now I've only a rough idea of upholstery, if I was being paid I'd probably source it out to a friend ... So feel free to point out any goofs ! (That goes for anything tbf, I can take it ) ImageImageImageImageImageImageImageImage
Think it turned out ok, the black line of the seat is very unforgiving, so a subtle bump or two...and the underside is a *bit of a dog's dinner... Almost forgot to knock off the arrises on the seat backer!... The white polyester is to even out and act as a 'lubricant', I believe it's called I stretched the seat and stapled the same way as you'd stretch an art canvas, splitting opposites - iykwim
Using some of the spare suede I've double sided taped it to some art mount before hot melt gluing in.
I can almost smell the finish line... Cheers Image
Jimmy Mack
Postby Jimmy Mack » 05 Dec 2018, 18:33
All done.... Shame I broke the mirror, Rodney u plonker! ImageImageImageImage
Jimmy Mack
Postby RogerM » 05 Dec 2018, 19:21
That looks like the DB's Jim. Smashing job.
"Mirror, mirror on the wall, why are you in pieces on the floor?" :lol:
RogerM
PreviousNext
Return to Projects & WIP
Users browsing this forum: Bing [Bot] and 16 guests
