It is currently 29 Mar 2024, 07:59
Re: Mike's extension & renovation (oak paneling)
Postby Mike G » 24 Dec 2018, 21:17
She did. Her bed used to be in the corner there, where the pot plant is now.
Postby Phil » 26 Dec 2018, 05:45
Very smart Mike.
Postby Pinch » 26 Dec 2018, 13:56
Love the lock Mike! Using steel from the wheelbarrow to make those straps is so creative - brilliant stuff!
:text-bravo:
I'm experiencing creative withdrawals when seeing these creative projects.
Pinch
Postby Andyp » 28 Dec 2018, 20:07
Posts pertaining to some users having problems viewing images on this topic have been moved to the Technical Issues board.
viewtopic.php?f=31&t=3765
Re: Mike's extension & renovation (porch internals)
Postby Mike G » 14 Jan 2019, 15:11
Ever since I built the porch, it has looked like this inside:
I decided it was time to make this a bit more presentable. This means insulation and lining the inside, ready for plastering. First up, battens all around the sides of each panel, set C.15mm back to allow for the plasterboard and plaster thickness:
Next, cut the insulation to size, and push it into place:
To be very clear, this porch is isolated from the house thermally, in that there is an insulated wall and door between the porch and the heated part of the house. The porch remains unheated. So the insulation doesn't really have much of a heat retention purpose. I's main purpose is avoid having unventilated voids, which are to be avoided whenever possible.
Next came plasterboard:
Before I could plasterboard the ceiling, I needed to support the house end of the oak ridge beam, which is structural, and was only on a temporary support. I made this:
I hate having that much sap wood in anything made of oak, but I only have scraps of construction oak left, so I didn't have much choice. Here it is in place above the door:
This enabled the fitting of the ceiling plasterboard, which isn't easy to photograph:
Postby DaveL » 14 Jan 2019, 15:58
Just fitting the plaster board makes a huge difference, I think the plaster will top it of.
Regards,
DaveL
Postby MY63 » 14 Jan 2019, 22:04
This whole project has been fantastic to follow I can’t wait to see what you do next :lol: although I hope a break is first on your list.
MY63
Postby Mike G » 14 Jan 2019, 22:20
A break? I'm cycling a thousand miles down to northern Spain in the summer, if that's what you mean. In the meantime, too much drawing, too little workshop time.
Postby Norty Raskel » 16 Jan 2019, 19:49
Hi Mike,
What thickness of wood wool board did you use on the porch, 15 or 25mm?
I'm envious of your Spain trip, I haven't been on a tour since our Sweden trip in 2015, I've just been too busy on the house.
PS could you check your spam, I sent you an e-mail the other day
Jon
Norty Raskel
Postby Mike G » 16 Jan 2019, 20:27
I replied to it, Jon. You might check your spam. ;)
15mm, BTW.
Postby Norty Raskel » 16 Jan 2019, 21:15
Guilty!! :oops: :lol:
Thanks Mike
Norty Raskel
Re: Mike's extension & renovation (sheds)
Postby Mike G » 04 Sep 2019, 17:28
I have news. Exciting news. Shed news......
My neighbour in our old house used to call me Mike Fivesheds. I am thrilled to report that we are now back up to that minimum quota. Unfortunately, due to camera issues, I don't have much to show of the construction of the potting shed. You'll recall that last we saw of it it looked like this:
Well, that spine wall went up and up and up. Whenever I had a spare day I'd go and lay a few more bricks or blocks. Once it got vulnerable to the wind I built a 3x2 frame to brace it, and eventually when it got to full height, I bolted on a plate and made a roof of 6x2s:
Ooooh, look at that wedged scarf!!!
As luck would have it, I was involved as project architect in the re-roofing of my local pub. The old roof was stripped, and some post war concrete plain tiles were going to be chucked out. They were in good order, and nicely weathered, so I snaffled a couple of thousand of them. They look pretty good on the potting shed roof, I reckon:
The windows are saved from the house (they're 1960s softwood), and the part-glazed oak door is the old back door of the house. One of the windows needed a a new cill and a scarf to repair a mullion:
I haven't quite finished lining the inside, and my wife has moved in already:
And that's not it!! In other exciting shed news, with hundreds of tiles left over after doing the potting shed I decided to re-roof this beauty:
That was a bit of an emergency overspill shed I built when I had to move my tools out of the house last year. I stuck a quick mono-pitch roof on it and left it unfinished. Well.....
Off with the old:
Some 4x2 rafters and a 6x2 ridgebeam:
Membrane and battens:
And hey presto, a new roof:
The feather-edge boards sit in a pile awaiting painting, so this will soon be finished.
You'll all be thrilled to hear that I am putting the final touches to a planning application for 3 more sheds (being on former agricultural land, they don't come under Permitted Developments), and one of the existing sheds will be demounted and moved to form a chicken coop. I will then be Mike Eightsheds and life will be complete. :lol:
Postby DaveL » 04 Sep 2019, 17:40
I have a definite case of shed envy!
Regards,
DaveL
Postby Karookop » 04 Sep 2019, 19:18
Thanks for the nice posting Mike! Surely you are into sheds big time and with style! Out of curiosity, what type of fruit are growing on the tree in some of these recent pictures? Oh, and I have to ask, what is the status of your braaiing facility?
Best regards from SA.
Karookop
Postby Mike G » 04 Sep 2019, 19:51
Hi Carel, good to hear from you.
We have 4 or 5 types of plum here. The small ones near the smaller shed are known locally as "bullus", an ancient and semi-wild ancestor of modern plums. Makes great jam. The bigger ones on the bigger tree by the potting shed are green gauges, the most delicious of all the plum family in my view. They make great eating straight from the tree.
Postby Malc2098 » 04 Sep 2019, 21:19
I like a nice wedged scarf!
Postby Jimmy Mack » 04 Sep 2019, 21:43
8 sheds ...I clearly need more sheds!
Love the potting shed green feather board, excuse me from (most likely) being behind... Is the other side the green house?
Mike, you have so many projects ticking over, I don't know how you juggle it...I can only imagine that some day they will all come into glorious alignment... Or perhaps they'll be another shed
Great stuff as ever, Jim
Jimmy Mack
Postby Mike G » 05 Sep 2019, 07:58
Jimmy Mack wrote:8 sheds ...I clearly need more sheds!
I simply can't fathom how anyone can manage without 8 sheds. There is the workshop, of course, and a separate store shed (the one I've just re-roofed). The new potting shed is backed up by the mower shed, which will also have the bigger garden tools. It is currently the bike shed, but there will soon be a new one of those. The current garden shed will be moved to form a chicken shed. The new outbuildings proposed include a garage, a firewood store, and the new bike shed I mentioned. The garage will have a bin store as a lean-to.
Exactly that. I'm going to be checking on western red cedar prices this morning so that I can make the frame for the glasshouse over the winter.
I certainly hope not. I wouldn't have anything to do!! :)
Postby Rod » 05 Sep 2019, 13:03
Eight sheds - sadly some of us don’t have the space.
Re: Mike's extension & renovation (utility cupboards)
Postby Mike G » 06 Sep 2019, 15:12
Catching up on some photos from before my ride to Spain...
The utility room has been a nightmare dumping ground for far too long, so I set about sorting it out. I bought some PAR, some ply, and some paint. Firstly, the frame (proper joints, you'll note):
The panels are just bridle-jointed 3x1s with 6mm ply panels:
It's a narrow room, so this is the best I can do for a photo, I'm afraid. Here it is with 3 coats of Bedec MSP:
Spot the cock-up:
This cupboard won't have the mops etc when I've done the understairs cupboard (which of course has to wait until I actually have some stairs....):
The wellie drawer neatly holds 4 pairs. Great through the summer when they're not in use:
The airing cupboard above the boiler. Access to the boiler is via the panel below, which is removable:
The seat and back panel with coat hooks:
The latter hides a little secret:
It's pivoted rather than hinged so that the coats don't have to be removed to open it:
Postby Andyp » 06 Sep 2019, 16:10
Who says trefoils can only be one way up? :)
Postby 9fingers » 06 Sep 2019, 16:17
Excellent work as always Mike.
I really like the coat rack/door idea. Currently racking what is left of my brain to think of how I could implement your spacesaving idea here.
Postby TrimTheKing » 06 Sep 2019, 16:23
Very nice indeed Mike.
:obscene-drinkingcheers:
Postby Mike G » 06 Sep 2019, 16:54
Andyp wrote:Who says trefoils can only be one way up? :)
Yep, that's the cock-up. God knows what went wrong.
Postby Malc2098 » 06 Sep 2019, 20:47
Nice.
PreviousNext
Return to Projects & WIP
Users browsing this forum: Majestic-12 [Bot], Mike G and 19 guests
