So I have not been totally idle over the wet weather winter. I have moved into the single garage which has been extended slightly and the majority of junk has been kicked out; it is still a bit on the small side.
So my logic was that i can collapse it down and go off and help my mates with a bit of DIY and if I need to use the space for temporary storage i can put it out the way.
So I downloaded the Ron Paulk plans and had a crack at it. Pretty pleased how it turned out although there where a fair few c*ck ups on the way.
Anyhow here you go, proof i did it:
