It is currently 25 May 2018, 14:06
Abrasive paper help.
Postby Hudson Carpentry » 31 Jul 2016, 06:45
Hello,
Seems I'm going back on the tools so I'm trying to replenish all the sundries I'm used too.
While using a palm sander I used to buy rhynogrip hook and loop on the roll. Brilliant abrasive but I can't seem to find any to purchase now. EBay just brings up a load of cheap looking paper.
The lads have been using the da discs but it's not the same, the holes in the da disc just cases problems while sanding edges and curves.
Any recommendations for rolls of 115mm wide velcro backed stuff. We use grits 80 120 240 320 500.
Thank you
Hudson Carpentry
Re: Abrasive paper help.
Postby 9fingers » 31 Jul 2016, 08:15
Ive been converted to Mirka Abranet abrasives for both disc and pad use. Not sure if it is available on the roll but there are several cut sheet sizes available. Not cheap but it really lasts.
Hth
Postby Deejay » 31 Jul 2016, 09:22
Hudson Carpentry wrote:Hello,
Thank you
Try
http://www.turnersworkshop.co.uk/woodtu ... l#Abrasive
Deejay
Postby Rod » 31 Jul 2016, 09:29
Another +1 for Abranet especially if you extraction with it.
Postby Malc2098 » 31 Jul 2016, 09:40
And another +1 for Abranet, especially on the ROS.
Postby RogerS » 31 Jul 2016, 12:22
Abranet every time. Preferably with extraction.
And you can buy it in on the roll.
Postby Hudson Carpentry » 31 Jul 2016, 20:06
I do like abranet but never used them on a palm sander. Any links to rolls? Struggling to find anything.
Sent from my SM-N910F using Tapatalk
Hudson Carpentry
Postby Malc2098 » 31 Jul 2016, 20:10
One of the guys sent me this link a week or so ago. They're not rolls but are standard rectangular sizes.
http://woodworkersworkshop.co.uk/epages/eshop814530.sf/en_GB/?ViewAction=View&ObjectID=21042110&PageSize=30
Postby Doug » 31 Jul 2016, 20:22
Doug
Postby 9fingers » 31 Jul 2016, 20:44
Hudson Carpentry wrote:I do like abranet but never used them on a palm sander. Any links to rolls? Struggling to find anything.
I get mine from this lot via ebay mainly because they do mixed packs. You might find cheaper for the rolls and single grit packs.
http://www.southernfilters.com/product- ... rka-rolls/
Postby Woodbloke » 06 Aug 2016, 09:14
Plenty of different sizes of individual sheets as well as rolls at Axminster - Rob
Return to Finishing
