It is currently 29 Mar 2024, 06:20
RogerS wrote:stu wrote:The only sensible way to do it is to have them both sides of the glass. Will be a mess otherwise.
A fair point, stu, but that will push up the price too much. I'm just going to have to see how it goes.
stu wrote:RogerS wrote:stu wrote:The only sensible way to do it is to have them both sides of the glass. Will be a mess otherwise.
Why not do half the windows both sides?
How much were they, relative to the cost of the orangery ?
will1983 wrote:Instead of having another 72 CNC cut could you not use one of the existing ones as a pattern to make another 72 for inside? That would be a fair bit of work but would be a lot cheaper than the CNC route.
The ones inside could have a different profile, maybe just a simple roundover for easy of construction?
If it was me I know that the issues the other guys have mentioned would drive me mad once the structure is finished and would draw my eye every time I looked through one of the windows. Time and few more quid spent now would prevent that.
This is isn't a criticism at all but you've done such a smart job of the rest I think it's a bit of a shame not to finish it off to the same high standard.
Will
RogerS wrote:stu wrote:RogerS wrote:[quote="stu"]The only sensible way to do it is to have them both sides of the glass. Will be a mess otherwise.
stu wrote:It was a rhetorical question. I cant believe the cost of getting some more done, in the grand scheme of things, is material.RogerS wrote:stu wrote:...
That would be unfair on Chrispy who say how much.
Jonathan wrote:Rodger
CT1 or polymer silicone will work.
Do some research and get one that doesn't yellow.....used one recently that was crystal clear to join glass in a glass fronted hexagonal sauna.
Make sure you get plenty on with no gaps or air pockets.
I would try pushing it on and not attempting any clean up of silicon untill its dry.
Jonathan
Sent from my SM-J530F using Tapatalk
Jonathan wrote:Rodger, I'm not in the shop at the moment but soon as back there I will see if I've still got it.
RogerS wrote:It was a rhetorical question. I cant believe the cost of getting some more done, in the grand scheme of things, is material.stu wrote:RogerS wrote:[quote="stu"]...
Mike G wrote:Are you planning on gluing it on with the glass flat (horizontal)? Because you'll have quite a bit of fun trying to do it with the glazing already fitted.
Jonathan wrote:Here you go Rodger.
Mike G wrote:I trust you didn't pay for that.
