Woodbloke wrote:MY63 wrote: The last time this happened I had to buy a replacement pad (not cheap) It is a black and decker random orbit sander. Has anyone got a fix.
Here's a dead cheap fix. When the pad wears out, head for you local haberdashery store and buy a metre or two of 50mm wide Velcro strip which ought to set you back about £2. Then proceed at a leisurely pace round to your local shed and buy a tube of impact adhesive. Cut the Velcro to fit, stick the strips to the pad and trim to shape with a Stanley knife. If there are any holes that need to be made in the Velcro, I use a 10mm leather punch to make them. It's cheap and it works; I'm on the second pad for my little Festool sander - Rob
Sounds like a plan as cunning as a very cunning thing! I'll try that on my triangular sanding pad on my multitool.
