It is currently 24 May 2018, 20:45
Vacuum lift
Vacuum lift
Postby RogerS » 03 Jan 2017, 10:23
Saw this on a TV programme recently and thought the idea rather clever. Basically it creates a vacuum above the lift capsule and up you go !
Re: Vacuum lift
Postby Andyp » 03 Jan 2017, 10:50
certainly more fun than a stair lift.
Re: Vacuum lift
Postby Malc2098 » 03 Jan 2017, 10:57
My belly would slurp against the glass!! :D
Re: Vacuum lift
Postby RogerS » 03 Jan 2017, 11:07
Malc2098 wrote:My belly would slurp against the glass!! :D
Given the size of the occupants who went up in one, in the last episode of 'Escape to the Chateau', I don't think you need have any worries, Malc !
Re: Vacuum lift
Postby Malc2098 » 03 Jan 2017, 11:17
Saw it! Love the show! He's good value for money!
Re: Vacuum lift
Postby RogerS » 03 Jan 2017, 11:26
I agree but whenever I see him, I'm just itching to get out a pair of scissors and trim that moustache!
Re: Vacuum lift
Postby Malc2098 » 03 Jan 2017, 11:29
That's part of his value!! :D
Re: Vacuum lift
Postby Mike G » 03 Jan 2017, 11:57
An answer in search of a problem. Hauling lifts up with a cable works beautifully well.
Re: Vacuum lift
Postby RogerS » 03 Jan 2017, 12:23
Mike G wrote:An answer in search of a problem. Hauling lifts up with a cable works beautifully well.
In a house ? This lift is perfect for a house. Minimum height needed at first floor level is 2.7m. You can't do that with cables.
And cost? No idea what the price would be for a cable lift but I'll wager it is significantly more than this elegant solution.
Re: Vacuum lift
Postby Tusses » 03 Jan 2017, 12:27
I would have thought a cable could go sideways, as well as up and down. just need a pulley wheel to change direction. then the motor could be anywhere ?
yes .. I think too much ! lol
Tusses
Re: Vacuum lift
Postby RogerS » 03 Jan 2017, 12:28
I would have though a cable could go sideways, as well as up and down. just need a pulley wheel to change direction. then the motor could be anywhere ?
Space for the motor and the cables? Sledgehammer approach.
Re: Vacuum lift
Postby Mike G » 03 Jan 2017, 13:01
Nah.....I used to design them into buildings all the time. A lot of disabled lifts are pushed up from below by hydraulics, rather than hauled up from above by cables. But again, simple, known technology which works beautifully, and cheaply. As for floor heights, well, I've designed and overseen disabled lifts which only went up a metre or so. I say again, a vacuum system is utterly unnecessary. It may look neat, with the lack of any visible means of support for the "car", but it's pointless.
Re: Vacuum lift
Postby RogerS » 03 Jan 2017, 14:04
Hydraulics....Surely they will need space below the ground floor...sounds like a lot of excavation into foundations and a lot of unnecessary work.
The point regarding the floor height I didn't explain very well. I meant the height between floor and ceiling at the first floor level. All that the vacuum lift needs is 2.7m. Your cables are going to have to go into the loft together with that motor.
And cost-wise ?
How much would a hydraulic lift (including installation and excavation) cost for a normal two-storey house?
Or a cable -lift (including installation). I'd be very curious to know.
Re: Vacuum lift
Postby Tusses » 03 Jan 2017, 14:20
" I know nothing "
as Manwel would say ! lol
but I am a thinker !
but I'd imagine a counter weighted lift, wouldn't take much moving , however it's powered ?
Tusses
Re: Vacuum lift
Postby 9fingers » 03 Jan 2017, 14:32
Tusses wrote:" I know nothing "
How would you counter weight a lift that has to ascend both empty as well as fully loaded? :eusa-think:
Re: Vacuum lift
Postby Tusses » 03 Jan 2017, 14:39
You could at least counter weight the empty lift weight. Even a little more, so you are lifting the weights when it's empty, or a person or 2 when it's occupied.
I'd go for the lift weight, plus half the intended payload as a starting point for calculations ?
Tusses
Re: Vacuum lift
Postby Doug » 03 Jan 2017, 14:39
Wasn't the point of this lift that there was minimal installation as it only took a day to install?
Also it easily fit in an existing building so taking up minimal space?
Usually it's installation costs that are the dear part of this kind of project so a pre made easily installled unit should offer good savings.
I didn't see the whole programme but saw a little about the lift as the good lady wife watching it, is he married to a designer?
Doug
Re: Vacuum lift
Postby RogerM » 03 Jan 2017, 17:11
I was now heavier than the barrel ........ :lol: :lol: :lol:
RogerM
Re: Vacuum lift
Postby Malc2098 » 03 Jan 2017, 17:13
Roger,
Love it!!!!!!
:eusa-clap:
Re: Vacuum lift
Postby Mike G » 03 Jan 2017, 18:21
RogerM wrote:.......I was now heavier than the barrel ........ :lol: :lol: :lol:
Halfway down.......... :lol:
Re: Vacuum lift
Postby Tusses » 03 Jan 2017, 18:23
:lol:
:text-bravo:
:text-lol:
Tusses
