It is currently 29 Mar 2024, 00:02
Malc2098 wrote:I've bought a couple of these for moving my stuff from the garage to the workshop when it's ready..
https://www.aldi.co.uk/workzone-rectangle-dolly-trolley/p/094753155249801
Lift your store onto it at one end and lift and drag the other end if it's not too heavy.
justaskin wrote:Hi Andy
Looking at the structure most of it appears interlocking. unless you can underpin the lowest beams in places to lift it high enough to get a complete length then centralise it on a wide pallet truck. Another way would be to put the 2 lateral beams with 2 stiff beams front to back and cut up a scaffold pole into say 1 metre lengths place 2 under each beam then as you roll it put another bit of scaffold in front and pull the contraption onto this roller bring the back roller to the front and start again. It worked for the Egyptians so I copied it to move my garden shed 4x2 metre's onto a concrete slab.
Richard
Tusses wrote:
could you cut the roof off , then re attach it ?
Robert wrote:Once you've emptied it of firewood how heavy is it?
it looks as if it would drag easy enough if it was on some wooden sleds. Thick plywood sled shapes screwed to each leg pair and drag it or lever it away...
Mike G wrote:Rollers, not casters. So long as there are continuous bearers underneath, a bit of temporary bracing, and someone to give you a hand, I don't see too much difficulty. You'll need a long lever, and some packing for the step..........and a camera!
Putlocks (short scaffold tubes) make great rollers.
Tusses wrote:castors get stuck in every little pot hole or bit of gravel.
RogerS wrote:Farmer with a forklift ?
Mike G wrote:I'll have 5p that any attempt with wheels fails, and that you'll succeed with rollers. Roundwood fence posts would do nicely. Putlocks, as I said. Maybe even a thick-walled plastic pipe.
old wrote:Can you lift it and support it high enough to do the work then resupport and make good before lowering back into position.
