It is currently 28 Mar 2024, 17:01
Phil wrote:What about these flexible metal woven pipe connectors that are used to connetc water pipe to toilets?
Doug wrote:You just need straight through radiator valves not the angled ones in the photo
RogerS wrote:
I've got straight valves, Doug !
Are they ground faced or the horrible nut & olive type that require a lot of movement to connect/disconnect?
Andyp wrote:A little OT but I was amazed to see my plumber using horsehair.
Doug wrote:Did you put stainless steel inserts in the plastic pipe before tightening the compressing fittings ?
Users browsing this forum: PAC1 and 18 guests
