It is currently 28 Mar 2024, 22:18
Tiling question
Tiling question
Postby RogerS » 05 Feb 2018, 19:27
OK...damn glad that I got rid of the second tiling muppet. He'd used massively thick beds of tile adhesive (costing me a fortune in the process) rather than build up with other stuff like cementitious boards or self-levelling compound. As a result, the muppet left a load of voids underneath some of the tiles.
How did I discover this? The sound of a crack as I happened to step on the wrong place was a bit of a giveaway. So remove the cracked tile and can see lots of voids under other tiles.
So I plan to pour in some runny self-levelling compound as I don't really want to take them up.
The bad news was that I clipped one of the adjacent tiles and so that one had to come up as well :( leaving a bed of tile adhesive.
So question, chaps ....
Could I get away with putting down something like a thin coat of No Nails or gripfill or something similar rather than go through the fag of getting up all that tile adhesive ?
Re: Tiling question
Postby 9fingers » 05 Feb 2018, 21:31
It looks like you only need a bit more tile adhesive to make up the levels?
Re: Tiling question
Postby MJ80 » 05 Feb 2018, 21:38
My tiler would gripfill or silicone little tiles down (think mosiac) if there was something after grouting that needed doing in a small area. For anything that size it would be adhesive. I would scrape it back so you had enough depth to butter the back of the tile. Sorry to see the state of what he did :cry:
MJ80
Re: Tiling question
Postby RogerS » 21 Feb 2018, 19:13
There's more over on the main The Builders Are Coming thread.
The dire 'lack of workmanship' continues.
Users browsing this forum: fiveeyes and 19 guests
