It is currently 28 Mar 2024, 11:44
Andyp wrote:No idea Roger but have you tried using your image to do an image search on Google?
Coley wrote:Looks like a glass shelf support
StevieB wrote:Plug socket converter for EU/UK? Apple do some really weird designs for this type of thing - the circular hole looks as if it could take a cable. It might make no sense when supplied with a UK 3 pin plug, but perfect sense if you get it in a different territory with an alternative socket/plug type?
Steve
Rod wrote:Was it loose or part of the packaging?
Could be to protect the pins of a 3 pin plug from doing any damage.
I’d put it away and wait until there appears to be a need for it.
I’ve got a box full of items that came with various appliances that seemed to have no function and I’ve still not used any of them.
Woodster wrote:I’d be surprised if it’s not pictured somewhere in the instructions, they normally are.
Failing that contact Neff?
Rod wrote:As a last resort can’t you get a fitter in to install these?
Users browsing this forum: Tellurian and 24 guests
