Paslode?
Bostitch with a compressor ?
Hammer ?
If you use something like a Paslode or a Bostitch how do you ensure that the nails go through the predrilled holes ? Does it matter ?
TIA
It is currently 28 Mar 2024, 23:31
Pinch wrote:In my old chippy days, it was always the good old hammer - a 20oz Estwing shallow claw with a polished face does the job nicely. We used to use 40mm galv wires for fixing.
I found the best way was to mark out the trimmer (as an example) first, with one squared line at 400 ctrs; fix one side of the hanger to the trimmer, then fix the other side with a joist off cut in the hanger without squeezing too much. Then bend the straps over & down the trimmer, nail fixing as you go. I also used to square line the straps down too, although not necessary.
RogerS wrote:No need, Pinch. Your second post made it al come clear, ta. I gather the nails are guaranteed to be short enough to hammer your fingers ! Talking it through with my builder, he Paslodes the beams lightly in place then slides the hangers up from underneath and nails them in position.
