It is currently 29 Mar 2024, 13:49
Woodster wrote:Have you looked at Panasonic? I think our current TV has three or four sockets. Personally I’m not keen on adapters.
Woodster wrote:The one in my link Andy has four HDMI ports and is only 40”.
I’m sure there are others I just did a search for tv’s with four HDMI ports.
Robert wrote:Old TV's had huge frames around them. New ones usually have very thin frames so you can't compare size for size.
Look up the overall sizes of a new TV then cut some cardboard to the size and try it in your room.
RogerS wrote:Is the relative lack of HDMI's on the Sony because they provide (thankfully) SCART connections which will take up real-estate ?
Andyp wrote:Tried that Robert still not happy.
Any thoughts on the component & RCA cable in lieu of HDMI?
RogerS wrote:Andyp wrote:Tried that Robert still not happy.
Careful. Are you talking analogue component or digital component ? And what about the audio ?
selectortone wrote:Andy, have you considered a multi-way HDMI switch? Lots of options available, from a simple manually operated switch to fully automatic 4k boxes complete with remote controls that detect which input is in use. Plug your devices into it and connect the output to your TV.
There are several on Amazon that won't break the bank and the reviews for most of them seem to indicate that they work well.
