It is currently 28 Mar 2024, 12:40
I've seen this done, by starting the hole at an angle, the edge of the bit, then straightening up.Andyp wrote:I will need to drill 10mm holes through tiles and concrete. I have always used the pointy type such as this for drilling wall tiles
https://www.fischer-international.com/e ... 0-x-15-100
But I now see there are flat diamond tipped bits for doing the same like this
https://www.screwfix.com/p/marcrist-pg7 ... -6-x/78470
Are they worth the extra cost? They must be a bugger to to use without a jig to hold them still.
RogerS wrote:Like everything else...it depends. It depends on the type of tile...terracotta? ceramic ?
Certainly on anything like ceramic, marble, travertine then those diamond drill bits are the dogs danglies. You still need to start the hole at an angle or you can buy kits that have a V-section, a sucker pad and a small pressurised bottle of water to keep the bit lubricated. I've got one and again think they are the DD's.
Or a simple appropriately sized V-shape in some MDF/whatever that is clamped to your tile.
Forget using them with concrete ....SDS drill is all you need.
Only downside of the diamond bits is that they can be fiddly to remove the core after or during the cut.
HTH
Andyp wrote:RogerS wrote:Like everything else...it depends. It depends on the type of tile...terracotta? ceramic ?
HTH
IIRC correctly they are frosrproof porcelain. No worries about the concrete, that is the easy bit I am just a bit scared of cracking a tile while drilling. I am even thinking of drilling a 12 mm hole in the tile to leave plenty of room for the 10mm sds through the concrete.
Woodster wrote:I’ve not used the diamond bits but I’ve heard they work well. Some folks suggest fixing a piece of wood with the appropriate size hole in to guide the bit until it gets started.
HTH
HTH
I wonder if the suction pad will wotk on the non slip surface of our tiles?
Andyp wrote:Woodster wrote:I’ve not used the diamond bits but I’ve heard they work well. Some folks suggest fixing a piece of wood with the appropriate size hole in to guide the bit until it gets started.
I read something similar. How does one the fix the piece of wood though?
Woodster wrote:Andyp wrote:Woodster wrote:I’ve not used the diamond bits but I’ve heard they work well. Some folks suggest fixing a piece of wood with the appropriate size hole in to guide the bit until it gets started.
That wasn’t mentioned but some double sided tape should do the trick?
RogerS wrote:I reckon you should be OK with one diamond bit as long as it's a decent brand.
Have you got a good hammer drill for the concrete ? I remember once when renovating a flat in London I needed to drill some holes into the concrete walls. Tried my battery Makita hammer drill and the wall just sniggered. Got out my mains larger hammer drill and tried again. This time the wall could hardly contain its mirth.
So I went out and bought a large SDS combined hammer only, hammer+ drill, drill ..that sorted it. Only drawback was it didn't have a reverse so when I later got a wood bit stuck in some old oak, there was much swearing and cussing trying to get it out.
Good luck.
Andyp wrote:Thanks Bob
I have some that is at least 12 years old. Probably past it's best. Will search for the .fr equivalent.
Andyp wrote:Thanks Bob, I bought a brush for the purpose and should be able to blow any other dust out with bicycle pump. Was certainly not going to buy a purpose blower for 10 euros.! Will vacuum as well.
Users browsing this forum: Mike Jordan, Woodbloke and 13 guests
