It is currently 29 Mar 2024, 10:30
9fingers wrote:Is there a flaw in my thinking?
9fingers wrote:......... there is about a tonne of water in there plus the occupant(s)........
Andyp wrote:If you buried it a) you could insulate it better and b) you would not have to climb into it.
Robert wrote:Is the electricity cost for what is essentially an air conditioner used for heating less than the running cost of a water pipe circuit from the gas central heating.. assuming there is GCH? Plus the kit needed would probably be cheaper.
Andyp wrote:Salt water stays warmer longer than fresh or retains heat better.
RogerS wrote:Bob, could you use one of those indirect IR thermometers to see where the greatest heat loss is coming from ? I bought one for under a tenner and it seems pretty accurate.
