It is currently 29 Mar 2024, 15:52
Doug wrote:I realise that Rog but I’d still & have laid stone of varying thickness the same as I’ve said just making up the thickness with mortar, it might take more mortar but starting on a flat surface is key for me. Start with the thickest pieces on a thin bed then make up the thickness of rest with mortar.
Also the strength of the thinner pieces is reinforced with the thicker bed.
Doug wrote:Yebbut I’d cut the 5” thick ones to get 3 out of those.
TrimTheKing wrote:Cheers chaps. What would I cut them with? The thickest one is approximately 30” x 18” and weighs a bloody ton!
Thy are also natural edges not square so at best I would have two usable faces and not 3.
Take the point about using them per thickness to make the digging easier though, thanks.
SamQ aka Ah! Q! wrote:Gawd, I thought my windows were boggin'...Roger has made me feel SO much better...
Sam
RogerS wrote:TrimTheKing wrote:Cheers chaps. What would I cut them with? The thickest one is approximately 30” x 18” and weighs a bloody ton!
Depends on what the stone is. Some stone will split with a simple bolster chisel and a bit of muscle. Ah...OK...see where you're coming from
SamQ aka Ah! Q! wrote:....
Your view looks smashing. Mine is presently filled by this autumn's first strutting, noisy, puffed-up-on- testosterone pheasant...daft feathered twerp.
Sam
oddsocks wrote:Mark, this probably isnt directly relevant to your path, but I have recently done a 50 sqm patio (partly why I've not been on this site recently!) using 'patio packs' of sandstone in 4 sizes. I found lots of advice from http://www.pavingexpert.com/ and paid to have a random paving plan done (approx £70) as my layout is an odd shape and i had a set amount of each size. http://www.pavingexpert.com/random02.htm
I thought I could design the layout myself - but that was probably the best value £70 of the project (that includes a 30p /sq m uplift for project packs as the computer algorithm need human intervention). you cna specify all the slab sizes, qty and gaps.
