It is currently 03 Mar 2024, 20:19
Can't view youtube vids since SSL update
Please list any and all bugs, feature requests etc in here and we can pick them up from one place. Only one bug/request per thread please, and make the title relevant so they are easy to pick out.
Postby Andyp » 16 Feb 2021, 08:56
you're gonna love this
Screenshot using the https url
(447.39 KiB)
screenshot without
(479.36 KiB)
this is the same for all youtube links on the forum.
OSX 10.11.6
Firefox 78.7.1esr (64-bit)
Same problem in safari Version 11.1.2 (11605.3.8.1)
Unless there are multiple members out there with this problem don't worry too much. I haven't got time to fiddle at the moment but will delve deeper later.
Re: Can't view youtube vids since SSL update
Postby Trevanion » 16 Feb 2021, 09:03
Good Spot, I can't either :eusa-think:
Trevanion
Postby novocaine » 16 Feb 2021, 09:26
Mark needs to replace a bit of code. :( maybe we just live with it for a few days till he's gotten over the last issue. :)
need to update it from http to https in the addbbcode22 (I think) script.
while we are on it there are a few warnings in the content, some of the icons are stored outside the HTTPS and are chucking up a warning . amusingly, it's the w3 xHTML Icon at the bottom of the page.
novocaine
Postby AndyT » 16 Feb 2021, 11:08
Ah, maybe that explains why my browser (Opera on Android) flags the site as insecure, even when I'm on the https option.
And I expect changing the links in update emails is also on the to-do list.
AndyT
Postby TrimTheKing » 16 Feb 2021, 12:12
Ah @rse! Little bit of digging and it's because the site is now secure that it doesn't like the old links off to non-SSL versions of youtube links so just displays them as blanks.
I tried modifying the BBCode to have SSL in it but that just changed the blank to a square saying that Shockwave was not supported so I regressed that. I also tried to add in a second line of code with https in but it didn't like that either.
Now I've replaced the youtube BBCode with an SSL version so the YouTube button now says YouTubeSSL. People will need to ensure that they are using the https version of the youtube link with the button.
I then need to go about finding a script that will allow me to bulk change all the old posts in the database to reflect the new BBCode otherwise the situation we have now is that all new SSL youtube links now work but all existing posts with embedded youtube video show as blanks. :evil:
Postby TrimTheKing » 16 Feb 2021, 12:13
novocaine wrote:Mark needs to replace a bit of code. :( maybe we just live with it for a few days till he's gotten over the last issue. :)
Where are you seeing these warnings because I'm not seeing any...
Postby novocaine » 16 Feb 2021, 12:32
I have the console running on a routine basis. :)
(411.08 KiB)
there is a script that will edit the SQL database and replace with HTTPs for you but I see that as a bit of a risk.
novocaine
Postby TrimTheKing » 16 Feb 2021, 12:32
http test - [youtube]G9LlXpy1u8A[/youtube]
https test -
Postby TrimTheKing » 16 Feb 2021, 12:34
novocaine wrote:I have the console running on a routine basis. :)
That particular one (icon_reimg_zoom_in.gif) was happening before the SSL cert was applied, I saw that last week when I was talking Mike through some stuff but put it low on the list to sort. I can't see what it is that isn't loading because everything appears to be loading on my screen...
The w3 one does load albeit having been upgraded by the browser so I'm not overly concerned with that one.
Re the script, have you got a copy of it? If so I have 3 DEV versions of the forum for testing on so I could run it on one of those to PoC it before going near live. I also have the system running hourly automatic backups of the DB just in case...
Postby novocaine » 16 Feb 2021, 12:49
I had a copy from quite a while ago, but I can't find it because....... LINUXed the machine.
I'll see if I can get a hold of it again.
novocaine
Postby novocaine » 16 Feb 2021, 13:59
novocaine wrote:I had a copy from quite a while ago, but I can't find it because....... LINUXed the machine.
A quick chat with my friendly site administrator pointed me to this thread with a PHP string function, this isn't what I remember but he proclaimed it would work.
https://www.w3resource.com/mysql/string ... nction.php
novocaine
Postby Eric the Viking » 16 Feb 2021, 14:12
Can you just run that from PHPMyAdmin?
You could at least test the filter that way (probably)...
E (half keeping up at the back).
Eric the Viking
Location: In the downstairs shower, trying to fix the leak.
Postby novocaine » 16 Feb 2021, 14:15
Eric the Viking wrote:Can you just run that from PHPMyAdmin?
trust me, I'm only half keeping up in the middle these days, gone are the days where I understood half of this. :lol:
novocaine
Postby Andyp » 16 Feb 2021, 20:37
Latest youtube vids are working fine,
Eg
viewtopic.php?f=19&t=5458
Postby TrimTheKing » 16 Feb 2021, 23:24
Andyp wrote:Latest youtube vids are working fine,
Eg
https://www.thewoodhaven2.co.uk/viewtop ... =19&t=5458
Yep new ones working fine it’s the old ones that are causing me a headache now. Will take a little bit of digging before I’m comfortable to run any scripts yes.
Postby Mike G » 14 Mar 2021, 08:12
Not sure of the difference between old and new videos but, they still aren't showing up.
Postby TrimTheKing » 14 Mar 2021, 09:23
What aren’t Mike?
Postby TrimTheKing » 14 Mar 2021, 09:26
Ignore that I’ve just seen your other post. There are now two YouTube buttons, please use the one called YouTubeSSL from now on.
I will remove the other one to avoid confusion.
It’s essentially to do with the work we had to do to put the SSL certificate on, that has meant that any non-secure sites that are linked to will not display.
It’s something I’m going to have to look into but not right now. Using the YouTubeSSL button will allow your videos to be viewed.
Postby Mike G » 14 Mar 2021, 15:20
Thanks Mark.
Here's a test for general amusment:
Postby TrimTheKing » 14 Mar 2021, 15:24
Mike G wrote:Thanks Mark.
Cracks me up every time that one. :lol:
Return to Technical Issues, Bugs and Feature Requests
