It is currently 29 Mar 2024, 10:38
Mike G wrote:I just let the bottom couple of boards overhang the edging more than the others.
What you have drawn would work if F/E, when nailed in place, added up to 25mm thickness, but it doesn't. You'll find the thickness around 30 to 32mm. Further, your corner detail would need a batten directly behind it as the side that is fixed to the frame is only "on" by 25mm, thus making the corner rather flexible.
Mike G wrote:That looks spot on.
Andyp wrote:Malc, do you think it might be easier to paint those ceiling boards before you put them up?
Malc2098 wrote:Andyp wrote:Malc, do you think it might be easier to paint those ceiling boards before you put them up?
It hadn't occurred to me. But, I've manhandled that last one up and down about 3 times, I'd end up looking like Banquo's ghost!
timothyedoran wrote:Vastern in Wiltshire is very good. Might be a bit far from you but they seemed very helpful to me.
timothyedoran wrote:Looks exciting. Which mill are you using?
MattS wrote:That cladding is going to look really lovely! Do you put it up green or let it dry a bit for shrinkage?
