Bents are simply cross-sectional templates of structural members, i.e., rafters, joists, posts, pilings, etc., that repeat on parallel planes along the length of the structure.But in my case, across the structure. The components of my individual bents are a pair of posts, a beam and two braces that comprise the long sides of my frame. You should be able to see a couple of posts and braces lying on the deck.
Although I knew my post bases were square, I needed to check the horizontal plane of the frame for squareness. It didn't take long to cut four short pieces of 4x4 and drill them and slot them. I was then able to check for squareness, test for any issues and then fettle at knee level instead of top of ladder level.
I should also be able to make up the trusses at either end and cut the rafters ready for frame raising day.
Talking of raising day, anyone prepared to lend some muscle?!
