It is currently 28 Mar 2024, 11:19
Malc2098 wrote:........Shed, Mike?!! Shed?!
Malc2098 wrote:A question, Gents. OSB 2 or 3?
And Jewsons sizes are 1200!!!!! x 2440. I've got to change all my rafters' centres!
Rod wrote:I used 3 for the 18mm roof but 2 for the 11mm internal cladding.
Malc2098 wrote:Thanks, Chaps. I'll research a local supplier. Access is not brilliant. Had a tree surgeon in a couple of years ago to remove an old apple tree; took four of them to get the SG up the garden! Once all the shrubs are down, there should be access by removing the fence panels.
woodstalker wrote:Malc2098 wrote:Thanks, Chaps. I'll research a local supplier. Access is not brilliant. Had a tree surgeon in a couple of years ago to remove an old apple tree; took four of them to get the SG up the garden! Once all the shrubs are down, there should be access by removing the fence panels.
My incinerator idea can be used to burn out a stump too, just sayin'
Andyp wrote:Nice work Malc. Can that machine be raised up so the shreddings go straight in the sack?
