It is currently 28 Mar 2024, 16:02
Malc2098 wrote:
For the rafters I did one central and two skewed.
RogerS wrote:Why use a compressed air powered nailgun (or even a railgun ? By a Paslode and then sell it on eBay when you're done. You'll get close to what you paid for it. I adopt that approach on all my projects.
spearos wrote:
A couple skewed for the birdsmouth too?
Malc2098 wrote:Yes. I probably overdid them, but I used three each either side of the ridge and three each at the birdsmouth. But the ridge and rafters were meaty at 145 x 45mm.
My mate today said there's no way mine will ever fall down!
RogerS wrote:Mark..just go with it. It's a workshop...not a piece of furniture (although I admit to the same degree of fretting at times).
spearos wrote:RogerS wrote:Mark..just go with it. It's a workshop...not a piece of furniture (although I admit to the same degree of fretting at times).
It's the structural implications of the ridge/rafter joint that I'm concerned about, not how it looks!
However, thank you guys Your comments make me feel more confident about continuing as it is and making the best fit I can with the ridge.
Malc2098 wrote:Doing well, Ole Son!
I like to see the timber framework. It was sort of sad after mine all got covered up by sheathing inside and cladding and roofing outside. But I know it's there!
spearos wrote:Malc2098 wrote:Doing well, Ole Son!
Cheers Malc! Your building looks great, it really does! So not seeing the frame isn't such a bad thing!
TrimTheKing wrote:Coming along nicely!
