It is currently 28 Mar 2024, 15:20
Mike G wrote:Just a quick note about the sizes you give. The 30 square metre thing is to be free of Building Control (the people who control how you build), and is based on internal floor area. The height thing is about your Permitted Development rights (ie building you can build without Planning Consent), so is a Planning matter (the people who control what and where you can build). You are probably aware of the differences, but I thought I should make that clear for readers who weren't so aware.
Tusses wrote:if you can get a bob cat , can you get a dumper truck ?
Our neighbour had a concrete truck on the main road and a dumper to move the mixed concrete round the back to the garage plot.
It was all done in no time.
cadman_4 wrote:
Next stage is either learn sketchup over the winter or just use 2D AutoCAD as I use that day to day. I knocked this up in a couple of hours.
Do you guys start the drawings off like this or draw the individual beams & joists first and build up from there?
And if you're only going to build it once you might as well have everything in
Malc2098 wrote:Ever thought of one of these?
They start at as little as £130. Could be built in to the build cost.
https://www.machinemart.co.uk/p/clarke-cml5-hydraulic-motorcycle-and-atv-lift/?da=1&TC=GS-020110194&gclid=EAIaIQobChMIsdXurdaJ1wIVSDobCh2qDQ9PEAQYAiABEgKj2fD_BwE
cadman_4 wrote: Nothing’s ever easy is it
Malc2098 wrote:Bloomin' modern bikes!
My R50, has two long bolts through the lower engine and frame, so all you do is carry the engine between your legs, step over the frame, let go of one end and put that hand through the frame and grab the engine again, lower the engine onto the two lower tubes, then go outside, rub your hernia and swear a bit!!
cadman_4 wrote:Malc2098 wrote:Ever thought of one of these?
I’ve already got one of those. Great bit of kit but on the bike I’m working on at the moment you need to have the engine on one of those and hoist the frame over the top and then lower it down to line up the mounting points. Nothing’s ever easy is it
Mike G wrote:300kg is 150kg. on each end of the beam as a point load. That's approximately the weight of two adults.
So, provided you don't allow this point load to fall on a single-depth plate mid-span between two studs, then there isn't the slightest problem in 4x2 framing supporting it
