It is currently 29 Mar 2024, 15:36
TrimTheKing wrote:Borrow or fashion a cat ladder such as the ones roofers use...? Lay it on the roof, hooked over the ridge, then climb up it and sit on it while working. Cheap, simple and time tested.
Malc2098 wrote:TrimTheKing wrote:Borrow or fashion a cat ladder such as the ones roofers use...? Lay it on the roof, hooked over the ridge, then climb up it and sit on it while working. Cheap, simple and time tested.
Could you use the 50x25 roof battens to make one.
Looking good!
cadman_4 wrote:
Good thinking Malc
So how did you fix your ridge or were they smaller sections that you could fit as you went along?
Malc2098 wrote:Result! Lateral thinking!
TrimTheKing wrote:Excellent. I like the look of that roof. Bet it sounds great inside when it’s raining too!
