It is currently 28 Mar 2024, 16:14
Mike G wrote:I'd suggest protecting your investment with a few bits of batten as cross-braces, Roger.
I should have looked into this thread days ago, because I would have suggested straw bales.
RogerS wrote:Mike G wrote:I'd suggest protecting your investment with a few bits of batten as cross-braces, Roger.
Straw bales for making a storage unit ? .......
RogerS wrote:That's a very good point, Bob. Initial gut feel is 'No'...although the floor is very dry. Probably all that wind.
On a separate note I just wish I had a separate empty building alongside into which I could put all the junk from the garage while I insulated and boarded up the garage.
9fingers wrote:....
Repeat on the rafters. Fit full sheets to those lines trimming as necessary. Then measure and scribe/trim offcuts line up with the errant joints.
RogerS wrote:9fingers wrote:....
If you've done the first line then why do you need to do one on the rafters ?
RogerS wrote:Thanks Bob, that's helped clarify my thinking.
Or taking the board up and down, up and down while I finesse cutouts etc. So I'll position the board to line up square with the joists and far enough away from the rafters so that it screws down flat-ish.
RogerS wrote:Surface wiring !
Andyp wrote:I don’t know how to put this but I would have painted them, white, before fitting them up there.
RogerS wrote:Andyp wrote:I don’t know how to put this but I would have painted them, white, before fitting them up there.
But then I wouldn't get to use my spray gun !
Andyp wrote:RogerS wrote:Andyp wrote:I don’t know how to put this but I would have painted them, white, before fitting them up there.
Eh? Why? Spaying them on the floor or leaning against a wall has to be easier then doing it on the ceiling.
