It is currently 29 Mar 2024, 13:55
Shed rebuild
Re: Shed rebuild
Postby Coolhands » 07 Jan 2019, 16:13
MY63 wrote:I like your window nice and simple was your frame too far back or was there another issue.
Michael
The issue is I only cut my featherboard up to the edge of the batten. I assumed the edge of the batten was the edge of the window, (as the blue material hid the true window edge). But it isn't - as can be seen by the earlier picture.
The red lines indicate the same position in both pics, and you can see how the window frame is over (by one 2x4" upright) compared with where the batten is.
(450.05 KiB)
(608.04 KiB)
Coolhands
Re: Shed rebuild
Postby Coolhands » 07 Jan 2019, 20:08
Yeaa baby! Motorbike in, for some immediate maintenance (I use as a daily commuter so need it back on the road for tomorrow morning! Now I can work in the dry & light). Haven’t had time to tidy up yet!!
(261.32 KiB)
Coolhands
Re: Shed rebuild
Postby MY63 » 07 Jan 2019, 21:10
I follow you now thanks for taking the time to explain.
Was there a reason why you only used the led panel in your modelling side or did you have the strip lights from the previous workshop.
MY63
Re: Shed rebuild
Postby Coolhands » 07 Jan 2019, 23:18
Yeah just trying to keep costs down, so I’m just reusing the 3 fluorescent tube battens I already had from before + 2 new LED on the posh side!
Coolhands
Re: Shed rebuild
Postby MY63 » 08 Jan 2019, 00:21
I appreciate that I ordered the wood for my frame today almost Had a heart attack :D
MY63
Re: Shed rebuild
Postby Coolhands » 17 Jan 2019, 01:29
Well just to close this off as it’s basically finished. Just need to finish electrics and tidy up around the site (garden etc). In the summer I will remake the doors.
By the way I bought the frame with the LED lights to make it easy. The transformer can be situated inside - there is enough depth. The lamp then slides in and final side clips on, it’s very easy to use but effective. (Note this does mean you need 60cms clear in one of the directions to be able to slide it in). For me the extra cost is worthwhile.
(417.39 KiB)
(199.54 KiB)
(142.68 KiB)
Final view. I will update in the summer once garden looks more pleasant! I need some stain to darken that window frame...
(456.64 KiB)
(303.02 KiB)
Coolhands
Re: Shed rebuild
Postby Mike G » 17 Jan 2019, 08:03
Congratulations, Coolhands, that's a fine looking shed which will last for generations. You must be very pleased. It cheers me somewhat that there are so many decent workshops being built, standing on plinths and with an airgap over the frame.
Re: Shed rebuild
Postby StevieB » 17 Jan 2019, 08:30
Excellent - really enjoyed reading this build, you should be proud of your achievements!
StevieB
Re: Shed rebuild
Postby TrimTheKing » 17 Jan 2019, 09:33
Excellent! Looks fantastic mate and a testament to your hard work and the fantastic guidance of Mike and many others on this forum.
Re: Shed rebuild
Postby Coolhands » 17 Jan 2019, 09:52
yes thanks all for the positive support along the way, it does get a bit exhausting at times during the build (with all the things in everyday life that are going on as well). I never would have know about the brick plinth until someone pointed me towards this forum so it cheers all :obscene-drinkingcheers:
Coolhands
Re: Shed rebuild
Postby Malc2098 » 17 Jan 2019, 11:01
Nice job. Well done.
Re: Shed rebuild
Postby Rod » 18 Jan 2019, 23:03
Looks like it’s been there for years, well done.
Re: Shed rebuild
Postby MY63 » 19 Jan 2019, 16:12
I must be honest the frames finish the job nicely I hope that you are pleased with the result it looks great.
MY63
Re: Shed rebuild
Postby tabs » 20 Jan 2019, 15:12
Very cool loooking shed, I especially like th look of the exposed rafters
tabs
Re: Shed rebuild
Postby Coolhands » 31 Aug 2019, 17:17
Couple of updated pics since I was tidying up in the garden. I’ve put shelving up inside now and finally started getting rid of junk (hoarding) to make it a more useable space.
Still need to make new doors.
(582.55 KiB)
(515.52 KiB)
(539.41 KiB)
(272.9 KiB)
(298.5 KiB)
(225.04 KiB)
(339.57 KiB)
Coolhands
Re: Shed rebuild
Postby TrimTheKing » 02 Sep 2019, 11:25
It's merged into its space beautifully. :eusa-clap:
Re: Shed rebuild
Postby Malc2098 » 02 Sep 2019, 14:25
Nice...and is that with carpet, too?
Re: Shed rebuild
Postby Andyp » 02 Sep 2019, 15:39
Malc2098 wrote:Nice...and is that with carpet, too?
Now that IS posh :)
Re: Shed rebuild
Postby Coolhands » 02 Sep 2019, 19:31
Haha yeah that’s on my ‘modelling’ (RC cars) side - I had some left over from a room, and underlay too! I’m going to put an internal door there to separate the 2 sides of the shed, which will also help if I want to warm it up in winter.
Coolhands
Re: Shed rebuild
Postby Coolhands » 30 May 2020, 16:45
Just finished making the new doors. Insulated and osb inside, treated shiplap outside. 2x4 for the door construction. I fitted 38mm wood for header and footer and I think 25mm on the sides for a door frame first.
(113.99 KiB)
(99.33 KiB)
(123.99 KiB)
Coolhands
Re: Shed rebuild
Postby Malc2098 » 30 May 2020, 17:11
Nice job.
Re: Shed rebuild
Postby DaveL » 30 May 2020, 20:59
Very nice, makes my bodging the repair of the fire wood shed seem even worse!
Regards,
DaveL
Re: Shed rebuild
Postby haigh218 » 15 Jun 2020, 16:04
Hi coolhands,
Can I ask how you have found your roof edging detail to perform in the rain? I have something similar (just about to stick down the EPDM edges) and wondered what you did with the corners too?
Thanks!
haigh218
Previous
Return to Workshop Builds
