Bit of an update, I finished interior and painted white, took a whole day believe it or not (don’t bother with cheap sprayers, I wasted an evening on one. Totally useless, now binned). Fitted bench at normal table height for sitting at for model making etc. Then promptly got everything in out the damp garden (FYI tarps don’t work)
- (233.79 KiB)
- (233.24 KiB)
Fitted window frame which meant I found I had made a mistake with featherboard when I cut the material open, so featherboard had to be taken down, and new put up the correct width to meet the window frame correctly
- (354.58 KiB)
This gap is wrong:
- (348.46 KiB)
Down she goes
- (333.22 KiB)
And up! With new boards
- (443.41 KiB)
Had double glazed unit made for 30 quid and fitted today. I sandwiched between wooden beading, and used a cheap window / frame sealer (in a gun) to seal.
- (414.36 KiB)
- (166.16 KiB)
Finally, I have fitted old batten units to my motorbike side, and wired up. And one LED wired up on modelling side. Used proper wire etc but is still attached via an extension lead at the moment. But can now switch on and off easily and see properly. Phone pic is bad - can’t cope with contrast - but in real life it is all nice and bright now.
- (227.02 KiB)
- (210.28 KiB)
Next up is to get proper electrician (a neighbour) to wire properly to house etc, but will be a few weeks yet.
